98 Maxima GLE Goes in reverse when in drive
Old Jan 27, 2016 | 09:44 AM
ganosha00's Avatar
I just replaced the transmission with a used one. The car will start in Park. When I put the car in reverse nothing happens, same with neutral. When i put the car in drive in goes in reverse. It will go forward if i put it all the way down in 1st. oh and sometimes neutral is reverse. Im lost. please help
Old Jan 27, 2016 | 03:56 PM
DennisMik's Avatar
You probably need to adjust the cable that goes from the shift lever to the gear selector switch on the transmission. It is possible the switch is bad, but more likely you just need to adjust the cable.
Do the Inhibitor Switch adjustment on page AT-188 and the Control Cable Adjustment on page AT-189.
Service manual link - http://boredmder.com/FSMs/Nissan/Maxima/1998/AT.pdf
Old Jan 28, 2016 | 08:27 AM
ganosha00's Avatar
Thanks Dennis. Made me recheck things in the linkage. Found the that the pin inside on the manual shaft holding the manual plate in place was broken. It worries me a bit how that retaining pin broke but now to just get it out to replace it
litch
May 13, 2016 11:13 PM
spamaster
Mar 23, 2016 03:38 AM
kirkhilles
Jan 29, 2016 09:45 PM
chevyman1980
Jan 27, 2016 04:02 PM
