99 SE cutting out at High RPM's 5500-6000
Old Mar 9, 2016 | 06:35 PM
slickblack94's Avatar
I recently bought a good cond. 99 SE LE manual trans. It runs good and Idles good but
if I take it up to 5500 + rpm's it cuts out and jerks. If I back off it starts running smooth again. Last night I was at 6k rpms in 3rd and the CEL blinked 6 times and went off. Anyone ever hear of this? I'm guessing it could be coils-spark plugs. I haven't checked for Hanshins yet.
Old Mar 10, 2016 | 08:05 AM
martyl45's Avatar
Check for codes, blinking CEL usually means misfire or multiple misfire. You can use a cheap obd II scanner.
Check out the Stickies for CEL codes.
https://maxima.org/forums/4th-generation-maxima-1995-1999/76800-check-engine-light-diagnosis-if-trouble-lights-read-here-first.html
Old Mar 10, 2016 | 08:59 AM
njmaxseltd's Avatar
Ahh, the 99 misfire once again. Coils, you can try to clean the section where the spring meets the coil in the stalk, or just replace them. The misfires usually show up under a load because the spark isn't strong enough.
Old Mar 25, 2016 | 06:20 PM
Since I switched to 93 octane it hasn't cut out 1 time......better power and not cutting out or flashing CEL... I got a decent deal on a used replacement set it case I need replacements.
Old Mar 25, 2016 | 09:33 PM
Gas is at crazy low prices. Splurge for the recommended 93 octane
Sounds like your coilpacks are on their way out (99's are famous for coilpack issues). But of course, check and replace spark plugs first.
Order to check/replace.
1. Spark plugs
2. Coil packs
3. Injectors
djloveu
Apr 9, 2018 05:54 AM
OmniPollicis
Mar 9, 2016 10:37 PM
coreyndz
Mar 9, 2016 05:46 PM
Max I am
Mar 9, 2016 03:12 AM
beechmon
Mar 6, 2016 06:58 AM
