Locked out of all gears?
Old Apr 5, 2016 | 01:07 PM
homeofbacon's Avatar
Yesterday I realized my clutch pedal was acting funny, it was catching really low, when it normally catches high. It travels down really easily, but is slow when coming back up. I filled up the clutch master cylinder reservoir with DOT 3 brake fluid(it was empty before), let it sit for a while, then tried to drive around the block to see if it fixed it. Well, I'm now locked out of every gear. What went wrong? The clutch was fine a few days ago, I didn't do any burnouts or anything lol.
EDIT: I'm absolutely lost. There are no clear or specific instructions, even in the Haynes manual. Where exactly am I letting the air out from? I've tried loosening the upper and lower valves but the nuts do not budge one bit.
Old Apr 5, 2016 | 01:28 PM
UPDATE: Goes in gear with engine off. Doesn't go in gear with it on.
Old Apr 5, 2016 | 01:36 PM
Icemule's Avatar
Did you bleed the master cylinder? If not that's your problem more likely. Use search to find out how. Very easy.
Old Apr 5, 2016 | 04:31 PM
JvG's Avatar
JvG
You might have a leaking hose near the slave cylinder. Or a bad slave. Not fun to bleed.
Many of us have installed a stainless steel hose which connects the slave cylinder directly to the clutch master cylinder. Doing that by-passes all of the failure prone lines which Nissan cursed us with.
Intrusions in the stickies.
tkelly0314
Apr 21, 2016 11:13 AM
Veloce06
Apr 7, 2016 05:37 AM
Ben2003GLE
Apr 7, 2016 03:10 AM
2014Maxima
Apr 4, 2016 07:12 PM
Xservice0183
Apr 1, 2016 06:47 PM
