need help with ECU purchase
Old Jun 15, 2016 | 05:45 PM
yippzter's Avatar
hey guys.
I need help with ECU. I found out that my ECU is fried and im looking for ECU with that number A18-N14 Z94. I couldnt find it anywhere for sale. The question is do i have to get the ecu with that exactly number or it doesn't matter? I have 1999 nissan maxima 4th gen.
Old Jun 15, 2016 | 06:00 PM
lux97Max's Avatar
1.Production date
2.fed spec or cali spec
3.automatic or manuel
Old Jun 15, 2016 | 06:56 PM
Maxima 97 SE's Avatar
in my experience it doesnt matter what model number the ecu is as long as it is from the same year car and its for an automatic. So if you dont find the same ecu, you can use the a different 99 maxima ecu. I once used a 98 maxima ecu on a 1997 maxima and the only difference was that evap code popped up but everything elese worked flawlessly. So for example I found one ecu on ebay that has the model number starting with 8Z but the other numbers are different A18 J60 E5S. This is the closest ecu you will find online probably. Heres the link and its from an Infiniti I30 1999 which is the same car as the maxima http://www.ebay.com/itm/Infiniti-I30...BnZHLQ&vxp=mtr Also make sure if your check engine light is on before you start the car and if it is on that means your ecu is fine and you dont need to waiste money. If the check engine light does not turn when you turn the car to the on position before you crank it, check the engine control fuse to see if it is ok. Other than that i thought my ecu was bad at one point and it turns out it wasnt bad at all and its really hard or rare or these ecu's to fail.
Old Jun 15, 2016 | 07:28 PM
lux97Max's Avatar
$289?? Lol.. i have one wayyy cheaper then that. And it does matter what ecu you put into your car. And evap code popped up u say? Lol means your car isnt running flawlessly could be cause you put wrong ecu in.
Maxima 97 SE
Feb 29, 2016 09:04 PM
R35
Feb 27, 2016 09:10 AM
bbsitum
Feb 20, 2016 12:05 PM
Alex.martinez514
Feb 13, 2016 01:17 PM
