MAP Sensor Relocation?
Old Jul 13, 2016 | 09:59 AM
Turbobink's Avatar
For those of us who have removed our OE intake snorkel, where did you relocate your MAP sensor and how'd you do it?
I've got mine "acceptably" re-positioned with a little bracket I fabbed up but I'm not sure I'm 100% happy with it and am wondering how everyone else has done it.
Old Jul 14, 2016 | 05:31 PM
Maximus909's Avatar
I dont have a MAP sensor only a MAF sensor
Old Jul 14, 2016 | 05:53 PM
maxprivate's Avatar
Black Lion
same here.
Im super charged so i had the MAF sensor relocated and installed in a custom aluminum block and had that welded to the intake elbow on my super charger. So I get all metered air into my intake manifold.
Old Jul 14, 2016 | 08:14 PM
reallywildstuff's Avatar
"What does that even mean Peter?"
If you're not running a MAP sensor you're...probably not Running.
edit: I concede the point that "MAP" is not the correct acronym (Nissan actually calls it a BOOST-SENSOR in the OEM parts catalog) however saying you don't run the item that the OP is referencing (even with the incorrect acronym) only serves to introduce un-necessary confusion into what is already a ridiculous soup of acronyms.
Old Jul 15, 2016 | 04:19 AM
Turbobink's Avatar
Originally Posted by maxprivate
same here.
Alright then ... my mistake.
Absolute Pressure Sensor.
And for the record:
MAP = Manifold Absolute Pressure Sensor
MAF = Mass Air Flow Sensor aka Mass Flow Sensor
I wasn't confused, simply inaccurate in my acronym.
Old Jul 15, 2016 | 08:03 AM
dwapenyi's Avatar
Good god you and CS_AR
What is it with those fantastically clean engine bays on a 16+ year old car?
Oh,and the cute little FPR. So small,nice and shiny
Old Jul 15, 2016 | 09:19 AM
i wasn't confused at all. Your Mass Air Flow sensor isn't even in that picture. You were clearly asking about the Absolute Pressure Sensor.
And for the record:
Old Jul 15, 2016 | 09:27 AM
same here.
The OP was asking about the "Absolute Pressure Sensor".
I presume you are in fact speaking about the MassAirFlow Sensor (as you indeed wrote).
You are in fact also running an AbsolutePressureSensor in addition to your relocated MAF, are you not?
http://www.fixya.com/fullimage.html?...es/bf3f5cd.gif
Turbobink's Avatar
Originally Posted by reallywildstuff
i wasn't confused at all. Your Mass Air Flow sensor isn't even in that picture. You were clearly asking about the Manifold Absolute Pressure Sensor.
My reply wasn't aimed at you ...
Your response was legit and appreciated.
Old Jul 15, 2016 | 09:34 AM
don't lose either of those screws for the pressure sensor - they are both a different length than the other "brass" emissions equipment screws and its difficult to source a replacement
i finally found mine in a tool tray and put it back on the car
Old Oct 16, 2024 | 06:31 PM
Tony Cervantes's Avatar
Map sensor
Attachment 13347
I HAVE A CUESTIÓN 97 NISSAN MAXIMA HAVE A MAP SENSOR If you have it. Can you point out with a photo where it is located and what liquid I can use to clean it?
Echarlie
Jun 14, 2018 10:36 PM
JSROOKS
Mar 17, 2018 08:16 PM
Montego Murph
Jul 13, 2016 08:17 AM
ac max 92
Jul 11, 2016 05:27 PM
radical1
Jul 11, 2016 06:14 AM
