Front right whine - seal or bearing?
Old Aug 9, 2016 | 10:48 AM
BobMax's Avatar
Like some other posts here, I have a light high pitched whine coming from the wheel bearing area of the front right. You can hear it at 3mph and higher... only with the window open. Very faint. I listened in with the stethoscope with the front end in the air and the wheel slowly turning and it was definitely the bearing area, not the CV joint. But, there doesn't seem to be any play in the bearing.
It is possible that the seal is making that noise? Can the seal be replaced without doing the bearing in a press? Or is it all one operation?
Thanks,
Old Aug 10, 2016 | 07:21 AM
BobMax's Avatar
Followup question: Anyone seen these be intermittent making noise? Maybe only after heated up?
Old Aug 11, 2016 | 04:24 PM
BobMax's Avatar
Solved: It was just the seal making noise. A little light lube stopped the issue.
tomtek
Mar 21, 2016 01:20 PM
Max16SR
Mar 20, 2016 08:41 PM
tallblazer124
Mar 14, 2016 08:39 AM
tmorales509
Feb 29, 2016 05:08 PM
nortynorty
Aug 29, 2000 07:24 PM
