Fog lights compatibility
Old Feb 26, 2018 | 07:47 AM
DizzyEdge's Avatar
What does that mean?
Are fog lights + brackets + relay + stalk compatible across '95-99, or is it 95/96 & 97-99 or some other combination?
Old Feb 26, 2018 | 01:40 PM
dsonnylal's Avatar
It is different from 95-96 and 97-99. I believe the relay is probably the only interchangeable part in either of the fog light kits.
Old Feb 26, 2018 | 02:47 PM
DizzyEdge's Avatar
Makes sense based on the 'refreshed' front end of 97-99.
Thanks.
Old Feb 26, 2018 | 03:25 PM
CallMeThatOneGuy's Avatar
You can use the same relay and the same stalk inside the car but the lights and the brackets are specific to their variant of the a32.
Old Feb 26, 2018 | 03:27 PM
saig's Avatar
I guess you don't need stalk. I think the fog switch on the stalk just jumps pins 31 to 32 of E113.
Old Mar 4, 2018 | 01:38 PM
CMax03's Avatar
No the entire system is identical except for the foglight assys....
Old Mar 4, 2018 | 07:28 PM
They do use different stalks..
Old Mar 5, 2018 | 07:28 AM
I stand corrected. I thought I put a 97 stalk on my 95 but maybe I'm wrong lol.
Old Mar 5, 2018 | 07:51 AM
They have different connectors.
Old Mar 18, 2018 | 07:07 PM
CMax03's Avatar
I have a junkyard stalk that was out a 4th gen thought was marked 96 and it worked fine with my 98...the other guys are possibly correct and maybe the Cars were marked wrong in the junkyard...
Old Mar 19, 2018 | 05:23 AM
max ride 41's Avatar
and you didn't know the difference? rear tail lights are different from a 95-96 as apposed to a 97-99 as well as the front and rear bumpers and grilles.
Old Mar 19, 2018 | 08:45 AM
DizzyEdge's Avatar
Well definitely 95/96 and 97-99 have different parts numbers, but I wonder if they still could be cross compatible regardless, like if the new parts were improved design but not incompatible design.
EvoTillIDie
Mar 27, 2013 05:28 PM
MOHFpro90
Nov 27, 2009 03:12 PM
MaximaPimpin
24
Apr 24, 2008 08:50 PM
95GLEMAXX
Feb 17, 2006 10:06 PM
DARTHSWAN
Jul 6, 2001 03:53 PM
