Intermittent dashlighting problem
Old Mar 28, 2018 | 04:35 PM
Frank50e's Avatar
Recently purchased a clean 95 and after replacing the battery the clock climate and radio backlighting have been intermittent in functioning.All were fine prior to battery replacement.They come on and off intermittent lay so I would assume the fuses are ok as they do work just not all the time.
Old Mar 28, 2018 | 04:42 PM
a32maxima4life's Avatar
Originally Posted by Frank50e
Recently purchased a clean 05 and replacing the battery the clock climate and radio backlighting have been intermittent in functioning.All were fine prior to battery replacement
seems like a fuse problem. Check out your fuses
Old Mar 28, 2018 | 05:04 PM
JvG's Avatar
JvG
Frank, you own a 6th generation Maxima.
You will find more applicable information of the 6th gen forum.
Old Mar 29, 2018 | 01:33 PM
Frank50e's Avatar
I altered my original posting to correct my errors I had the wrong year a
should have replylied to the two suggestions I got but just corrected my errors.Sorry
Old Mar 29, 2018 | 04:34 PM
JvG's Avatar
JvG
I agree with the suggestion about the fuse.
Chances are that the fuse is not actually blown.
But also that it's contacts are oxidated or corroded slightly. The deposits mean increased electrical resistance. Enough to dim lights, or trigger a cel code, like for the oxy sensors.
So I'd find the proper fuse, then sand the contacts slightly, or replace the fuse with a new one.
spta97
Nov 10, 2002 08:33 PM
maxima4me
Jun 10, 2002 02:24 PM
abbey
Nov 28, 2001 10:15 PM
gaios1
Feb 1, 2001 09:05 AM
Buzz
22
Jan 15, 2001 02:44 PM
