Bad power steering fluid leak....
Old Aug 10, 2018 | 05:14 AM
Brandon Weiss's Avatar
Hey there! Really enjoying my new (now 70,000 mile ) 4th gen 97' maxima, my first car and i'm learning alot! There are still many things i'd like to tackle to make this car last me. (including knock sensor, o2 sensors, and plugs. i seem to only get about 15-16mpg in the city, while alot of people say theyr'e in the 20's! Driving style may have something to do with it though )
Another one of those things being what i see as a heavy power steering leak, in that ive added a full quart in the first 1,000 miles ive driven this car. Every time i park, i'll come back to a stain on the ground. The leak is in the front right of the engine bay (from the driver seat perspective), in front of the radiator behind the front grille. There are 2 black rubber pieces of hose that act as bridges between 2 metal lines, they make a 90 degree turn going from parallel to the radiator face, to up toward the power steering reservoir, clamped on by what appear to be some sort of hose clamp. There is a lot of leakage below that, and the nearby portion of the radiator and everything below it has a nice coating of fluid.
I looked through the stickies, but couldnt find anything pertaining to my specific issue.
Is this a common issue? What would be the best way to tackle this (what has to be removed to be able to actually reach and replace the lines, i have a couple feet of the hose)
My only concern is dumping fluid everywhere when theyr'e removed.
Thanks in advance!
Old Aug 10, 2018 | 07:43 AM
nissan99's Avatar
My 99 does same thing in that area .. I replace the hose which is 3/8 and new clamps and still leaks a drop or two when parked .. I was thinking of useing silicone rubber adhesive at the end of the rubber hose to seal it to stop the leak .. also make sure your using trans fluid and not power steering fluid ..
Old Aug 10, 2018 | 09:12 AM
reallywildstuff's Avatar
Every part number you need is in this thread:
https://maxima.org/forums/4th-genera...ler-hoses.html
Old Aug 10, 2018 | 09:16 AM
DennisMik's Avatar
The metal lines that go to the front of the car and the loop in front of the a/c condenser coil is the power steering oil cooler. The power steering uses Dexron automatic transmission oil and the oil will rot rubber hoses after a while. Replace the hoses and use aviation style worm gear hose clamps.
Old Aug 10, 2018 | 10:28 AM
I have some lengths of 3/8in reinforced rubber fuel line/transmission line. I was going to use that, but i was concerned with kinking the hose going around the bend. If i make the turn a little wider, do you think itd be doable? If i dont have to id rather not shell out $60 for 2 little pieces of preformed hose.
Old Aug 10, 2018 | 10:42 AM
Well, turns out the elbow hose i need is discontinued! Looks like I'll have to make do with some regular hose.
Old Aug 10, 2018 | 12:15 PM
JvG's Avatar
JvG
Use oil line or automatic transmission hose.
no reason not to use a longer length of hose in order to make the bend withour kinking.
Old Aug 11, 2018 | 06:18 PM
Thats what i have! I plan on doing it this weekend.
edwardh1
Jul 2, 2016 12:06 PM
eyeball187
Jan 3, 2012 06:14 PM
tcaughey
Sep 10, 2010 11:57 AM
Maximeltman
Jul 18, 2010 03:11 PM
patelajit
Jul 5, 2006 08:56 PM
