would you re-surface these rotors?
Old Aug 15, 2018 | 07:13 PM
plat's Avatar
I'll be doing my front brakes soon and the rotors have some light scoring like this. You can feel it for sure but it doesn't catch your fingernail. Other side is the same.
Just curious if you would resurface/replace or just put in pads.
Old Aug 15, 2018 | 07:21 PM
JvG's Avatar
JvG
Depends on how much money you want to spend.
I've installed new pads on rotors which look like that. The braking action was fine after they had a chance to conform to the slight ridges. The pads lasted a long time.
Other people would have the disks resurfaced.
Yet the cost of new acceptable rotors is not all that much more money these days. The car won't be waiting for the rotors to be resurfaced. So you will be able to install the new brake parts quickly.
Old Aug 15, 2018 | 07:24 PM
maximaxi's Avatar
resurfacing rotors isn't worth it. You might as well just get new rotors
Old Aug 15, 2018 | 07:43 PM
plat's Avatar
Yeah I wasn't sure yet about resurfacing vs replacing. If I was going to do something with them I'd consider how much Napa would charge and how long it would take.
But sounds like you were fine just doing pads so I'll probably do that.
Old Aug 15, 2018 | 08:33 PM
reallywildstuff's Avatar
Got a pic of rotor thickness?
Old Aug 15, 2018 | 08:39 PM
maximaxi's Avatar
Actually, I always replace the rotors when replacing the pads. In particular, I like Wagner's coated rotors. The coating really does help stop the rust.
My I30 has EBC Ultimax "Blackstruff" pads and Wagner E-coated rotors, and they are awesome
Old Aug 16, 2018 | 09:19 AM
This. If your rotor thickness is too thin as it is, resurfacing is not even an option. And if they're too thin, it's time to replace them IMO. I wouldn't put new pads on rotors that are too thin to take a re-surfacing.
If your rotors have enough meat on them, resurfacing should only cost you $20 at your local Pep Boys. Many people have had good luck simply slapping on new pads and calling it a day. Just bed the new pads in well.
Old Aug 16, 2018 | 11:04 AM
krismax's Avatar
Father of the 00 VI
Wow i can go years without replacing rotors. Manual trans + let of gas before braking well ahead let car coast saves gas and brakes.I really don't see people do this. I put 2-3 sets of pads on a set of rotors.
Old Aug 16, 2018 | 12:44 PM
KP11520's Avatar
Good luck finding any place that still turns rotors! Many years ago, it was $15 each (here on LI). Can't imagine what they'd charge now.
Decent Rotors at NAPA start at just above $30 each.
And since you also need pads, you might look at rotor/pad kits.
I use this kit and it's a nice stopping power improvement over everything else I've used in 210K miles at a very reasonable total cost: https://www.summitracing.com/parts/pwr-k660
Old Aug 16, 2018 | 07:53 PM
plat's Avatar
On closer inspection the rotors looked better than I thought. The old pads seemed perfectly smooth on the friction surface so I don't think the scoring had any effect.
I just put in new pads and all is good. New ones semi-metallic and are definitely more grabby than the old ones so maybe the old are ceramic?
Is it strange that it look like the inner side of the rotor is thicker than the outer?
Both rotors were the same thickness (21mm) according to my non-digital calipers:
Old Aug 16, 2018 | 08:10 PM
plat's Avatar
Judging how much wear I've had on those pads over the last year and 15k miles, I think I could do 60-70k at least on a set of pads.
I do this too, just slow down in whatever gear I'm in to near idle and then go to neutral. I don't think it's worth the wear on clutch and trans to actually shift down though.
Old Aug 17, 2018 | 05:15 AM
CS_AR's Avatar
My 27 year old Q45 iat 155,000 miles is still running the original rotors that have never been turned. I just change the brake pads before they get a chance to damage the rotors.
Old Aug 18, 2018 | 11:27 AM
DennisMik's Avatar
When I am reusing rotors, I break the glaze on the metal by using fine sand paper, 150 or 200 grit.
Old Aug 18, 2018 | 09:30 PM
max ride 41's Avatar
craig, you do realize you have to go over 40 to wear out brakes and such, right?
Old Aug 18, 2018 | 09:48 PM
JvG's Avatar
JvG
I do too. The reason is that the heat caused glaze and pad deposit's needs to be broken. So the new pads will be able to confirm to the brake disks. Otherwise the new pads will skid over the glazed disk. The brakes would not work well.
92 Max
May 29, 2009 04:33 AM
NoMotive
Jan 6, 2005 03:40 PM
Kikcaffine
21
Sep 5, 2004 05:55 AM
BOSS
Mar 30, 2004 11:06 PM
worm
Sep 3, 2003 02:20 PM
