"Ignition switch"
Old Feb 8, 2019 | 08:41 PM
reallywildstuff's Avatar
"Ignition switch"
'98 i30 - 123k Miles
I desire to replace my "ignition switch" re "as the alternator turns". "The switch" is 20 years old and the (now non-repeating) weird lights on the dash are not a sign of good things to come.
I've already replaced all the other bits. If the new alternator or new battery had dumped, each would still be dumped - but it drives super nice, w no drivability issues to note at all. I took it to work and back again today - no issues.
re: replacing that particular electrical part that's "hot all the time" - is this the correct part # below?
https://www.infinitipartsdeal.com/pa...,998_001,48750
Old Feb 8, 2019 | 09:27 PM
DennisMik's Avatar
Yes, that is it.
Here is a photograph of the actual part -
Old Feb 9, 2019 | 08:41 AM
CS_AR's Avatar
I replaced the 98 model's switch a couple of years ago with an Intermotor. The 98 is my daughter's daily driver. She had an unexplained starting issue one day like the battery had died. So I decided the replace the switch since its not an uncommon failure item. No further problems with the new switch. I understand the switch works on other Nissan models. Don't be surprised if the new one has a tighter fit due to a new cable length. Not much price difference between Intermotor and OEM. I usually go with Intermotor, for select parts that I know, to get a better warranty and local exchange. Here's a picture of old and new switches below.
I stated moving from from Advance batteries to Interstate. I'm growing tired of 36 month replacement warranty batteries that are "programmed to fail" at 39 months.
I think the part number changed to US283 after I bought the one in the picture.
Old Feb 10, 2019 | 06:07 AM
I bought a $10 one off eBay for my daily beater. Will check back soon once it’s in.
Old Mar 4, 2019 | 10:21 AM
I replaced this. I got the OEM part # 48750-1E411 from www.infinitipartsdeal.com for $29.19.
The under-column pic is of the old switch as installed - check out the burn marks on the white/red and green/black wires.
Side-by-side shot below that - the new one is _longer_, so there's just a little bit more cable to snug up inside the column cover when putting it back together.
This car has been running really well ever since I rebuilt the injectors - but it had seemed like just a very little bit doggy at idle, and even slightly more so in what we call "colder" weather down here. Not bad enough not to drive it.
After replacing this switch, however - wow much stronger and quicker starts, and much better throttle response - and I'm pretty sure I'm not making that up.
I wish I'd replaced this 20+ year old electrical switch when I first started with the alternator problems all that time ago.
Old Mar 4, 2019 | 03:30 PM
CS_AR's Avatar
Congratulations. I think I should replace the one on the 99 model just to keep from having to deal with a failed switch at some point.
Old Mar 4, 2019 | 07:06 PM
JvG's Avatar
JvG
Long term owners of our cars recognize the wisdom of that statement.
Add the phrase "while you are in there anyway....:
So might as well replace well known iffy stuff when we get a chance to work on semi-related stuff.
Im thinking particularly about uim removal , fuel injectors, the egr, and other fluster clucks related to that.
Seems that our cars general weaknesses are well known. Oddly, the rest of the car is relatively trouble free.
Old Mar 4, 2019 | 07:33 PM
bvb_09's Avatar
LOL. I am using only interstate batteries, and have to replace them every 3.5 years ;-)
Old Mar 5, 2019 | 03:11 PM
CS_AR's Avatar
NO NO NO. I don't want to hear that..
Old Mar 5, 2019 | 03:18 PM
CS_AR's Avatar
Yep.. The rubber accelerator pedal covers seem to last without issue.
Old Mar 6, 2019 | 10:16 AM
PH98I30's Avatar
From what I understand, there are only a couple of car battery manufacturers that supply all the car batteries. I know of Johnston Controls and Exide. I am not sure if there are any others. They produce all the car batteries and brand them for particular companies. Does anyone else know different? I guess we could do a whole thread on who manufactures all the auto batteries worldwide.
Frank50e
Apr 2, 2019 05:34 PM
CS_AR
Feb 6, 2017 07:47 AM
CS_AR
Apr 17, 2016 11:27 AM
asand1
Sep 8, 2011 09:10 AM
smai555
Oct 26, 2009 10:30 PM
