'98 Trim? GXE, GLE, SE mystery
Please, validate. Spoiler, Bose, woodish look dash, power w/trk/locks, sec sys, buttons on visor, o/d, p/vinyl(?) seat(s) driver side. I looked at whatever stickers, door, under hood, engine specs, trunk, everywhere. I am assuming GXE, no leather, and not basic. Am I assuming correctly, and where could I find the info.?
Look for your third brake light. If the third brake light is inside the car (bottom middle of rear window) then you have a GXE or GLE. If the third brake light is on the spoiler only, then you have a SE. The SE does not come with the third brake light inside the car. The 97-99 GLE model will say GLE on the back of the trunk. The 95-96 will not.
The GLE was the only trim to include faux woodtrim for the shifter bezel, radio bezel, and power window switch cover.
I will assume the GLE for the lack of leather, and white gauges, because the SE does not fit. I need the info to buy auto parts, but the parts are interchangeable for basic maintenance, right?
My '98 has the faux wood exactly, as you describe, and the third brake light lower middle back window inside. It seems a bit crazy to fully load the car with options, minus the leather, but what do I know? It's weird, because seeing the Maxima with the leather seats did not look quite the same in its exterior view based on memory two years back. Is there a difference in profile, meaning sits lower? The SE looks more basic, also. Mine is comparable to a Honda, and often confused.
That is a SE model. All trim levels share the same V6 motor so hp is the same. The SE is sporty so it has a stiffer suspension and 16 inch rims, fog lights among other differences. The GLE is more luxury, so it's only offered with an automatic transmission and comes with leather. The GXE is basic, no leather, no Bose radio, steel rims with hubcaps etc. A fully loaded SE would be worth more in value in my opinion.
GLE is a luxury Maxima. Purchased by those who have the money. An Infinity I-30 is anot her step up.
SE is a sporty Maxima. It has some nice features, and money goes to performance rather than luxury.
Is this a/the reason for the clunking sound since replacing the shocks/struts in the rear??? I replaced the front end axle, and struts three months prior, because finances determined the brunt of wear took priority. Is there a noticeable distinction between the parts?
The SE and I30 models came with an additional plate that connects to subframe behind the front wheels.
The SE and I30T models had a different part number for the front strut upper insulator (top hat). The SE/T model insulator has thicker rubber.
cakemix
Oct 22, 2022 10:26 AM
coolhandmax
66
Nov 2, 2006 11:00 AM
