about to do a auto to manual 5spd swap plus some
doing a 5SPD swap. been goin through the site trying to find the complete swap done by a member but no luck yet. can someone point me to the right links? 🙏
lookin for all the info I can get a out the 5spd swap
trying to decide on 5spd or 6 spd manual transmission. want to know all the problem solving issues, pros and cons of 5 vs 6 spd swap. etc, etc. thanks!
Most links are dead by now so you'll need to hope web.archive.org has a copy of it.% speed swap link below.
https://web.archive.org/web/20190731...auto-5spd-swap
There may be some I'm forgetting but here's the list off the top of my head.
- 5 Speed
- PRO
- Cheaper
- Lighter Weight (~30 lbs)
- Easier to install
- Rod Shift Linkage = Direct Shifter Feeling (shifter feels connected to the car)
- CON
- Weaker Transmission
- VLSD is probably iffy at best since the fluid is nearly 20 years old now.
- PRO
- 6 Speed
- PRO
- Stronger Transmission
- Plenty of OEM gearing options
- Mechanical HLSD
- CON
- Heavier
- More Expensive
- Cable Shift Linkage = Remote shifter feeling (slightly detached shifter feeling, kind of like a video game shifter but not as extreme)
- Custom Parts to use with a 3.0
- Need 6mt timing ring made for 3.0 ECU
- Need JWT/Fidanza lightweight flywheel to use above timing ring.
- Need to cut & weld 6mt trans mount or use some adapter mount.
- PRO
All depends on what you want out of the car and how much you're willing to spend on it.
svillegas2253
May 25, 2013 05:03 PM
