Alternative options for draining transmission
Old Oct 5, 2021 | 02:45 PM
notAjetta's Avatar
Hi, I have just gotten my transmission fluid in the mail and am ready to drain the old stuff out and replace it with the new. I located the drain plug with the help out some members here, but I’m unable to remove the bolt as I cannot fit a socket on there and the bolt seems it will strip out before it loosens (corners are already rounding). Is there any alternative options for draining the fluid, or is there a way to fit a socket on there. Thanks
Old Oct 5, 2021 | 04:35 PM
Reality sucks's Avatar
There really is No other way. That will guarantee you get all the Fluid Out. Clean up the area and spray a few times with some PB Blaster spray to possibly loosen any corrosion. Re attempt this with a Brand New Socket and Pull Harder, the Bolt wont Break.
Old Oct 5, 2021 | 07:31 PM
schmellyfart's Avatar
Do you have the correct size socket for the drain bolt?
Only other option is to drop the entire pan.
Old Oct 6, 2021 | 09:50 AM
RA030726's Avatar
I'm nutty for Nissans
Lots of people used to say remove the neutral safety switch. Don't. It will break and cost more money, time and headaches.
Maybe you can suck/pump out the fluid through the fill plug.
Old Oct 6, 2021 | 10:12 AM
RA030726's Avatar
OP has a manual transmission. If it was an automatic just pull the hose off the cooler.
Old Oct 6, 2021 | 11:08 AM
notAjetta's Avatar
I’m not able to fit a socket on the bolt as there is a bracket in the way preventing me from doing so. So I had to try to use my 12mm wrench, but it seems to be just rounding the corners of the bolt. I’ll take a picture/video when I get back from school.
Old Oct 6, 2021 | 03:27 PM
RA030726's Avatar
I ground some material off my 12mm box end wrench to fit better.
Try an offset wrench.
Old Oct 6, 2021 | 05:17 PM
He didn't really specify either way.
Looking at his post history its clear now.
You try a box end wrench?
Old Oct 6, 2021 | 06:00 PM
notAjetta's Avatar
yeah, it’s rounding the corners of the nut. I know that if I try any harder it’s going to completely round the nut and I definitely won’t be able to loosen it then.
Old Oct 6, 2021 | 06:04 PM
notAjetta's Avatar
I gound some material off my 12mm box end wrench to fit better.
this might be the best option. Now I gotta go bug my friend for one lol.
Old Oct 7, 2021 | 09:24 AM
JvG's Avatar
JvG
I just removed the Vehicle Speed Sensor.
The oil came out very quickly.
Then I replaced the sensor.
Done.
Old Oct 7, 2021 | 04:50 PM
RA030726's Avatar
Done.
The speed sensor is on top. Do you mean the reverse/ neutral safety? You got it out without breaking it?!
Old Oct 8, 2021 | 03:07 AM
Turbobink's Avatar
Doesn’t have to be these brands.
Doesn’t have to be these sets.
Just pointing out that tools are available to address this very need.
They are likely even available for loan-out or rent at your local parts store.
Old Oct 8, 2021 | 10:02 PM
JvG's Avatar
JvG
I haven't looked at my transmission for some time.
As I recall there is a black plastic cylinder about 1.5 inches in diameter. It is mounted in the lower front of the transmission. It has one wire connected to it.
Its attached to tge transmission with a bolt or two.
I removed the wire and the bolts. I removed the sensor.
All the fluid came out at once. It's best to slowly remove the sensor so the fluid gushes out more slowly.
Old Oct 9, 2021 | 02:31 PM
maxprivate's Avatar
Black Lion
I believe the head on the socket wrench on a 3/4' socket wrench will fit in there perfect.. try it out.. I don't know the actual socket size but I know what mentioned will work. I think this might be for the fill hole plug.. can't recall.
and I have a Manuel transmission.. do not try from the neutral switch like said above, it will definitely brake.
Old Oct 18, 2021 | 09:22 PM
AMnissan's Avatar
tools are supreme to the job!!
and almost always,. If you like the tool keep it for future jobs. If you don’t have a use for it later, pass it on.
id go with the offset wrench then sockets
Old Oct 19, 2021 | 09:22 AM
notAjetta's Avatar
yeah, it has yet to round the corners yet, but I can feel it starting too. I bought a cheap 12mm wrench with a completely closed end that I’m just gonna file down to fit correctly.
Sean_a33
Jul 28, 2014 01:22 PM
PhillyDonut
Jul 13, 2005 11:19 AM
wcasskicker
Mar 31, 2004 04:23 AM
bmxsteve
Jul 25, 2002 02:31 AM
theMax
Feb 3, 2002 09:02 PM
