Is the wire harness for the drivers door easy to replace?
Hey,
So I am looking to replace my wiring harness in my drivers door because various things have failed ( marker light, switches are having issues, and so on. Most of the time it works but intermittently has issues. Can i pull the who harness out in one go? Does it connect somewhere I can unplug or is it more complicated than that. I want to pull one out of a junkyard Maxima and fix these issues.
It will come out in one piece.There is a connection hidden in the kick panel area. Inside the door are multiple connections and plenty of retainers.
Have you replaced the master window switch first?
When you look for one, make sure it matches. Bose vs non Bose for example, the harness is different. Probably a non issue if it comes from an I30 and not a Maxima.
update the 2 maximas at the yard were non Bose models. I guess I need to wait for new cars to land in the yard
LILMAN
Aug 31, 2009 12:32 PM
