R34 headlight retrofit
Old May 12, 2022 | 03:51 PM
dbaray's Avatar
Im sure its been answered before, just completed a full retrofit build on some R34 style headlights. Low beams work great but when i turn on the high beams, the low beams cut off and only the highbeams turn on, looks kind of weird when its just the highbeams on. Any way to solve this? Or is my headlight switch going bad.
Thanx
Old May 13, 2022 | 02:05 AM
Rit's Avatar
Rit
Iy is working as designed. It is illegal to have both low and high beams on at the same time.
Old May 13, 2022 | 04:58 AM
dbaray's Avatar
Im not trying to run them both at the same time all the time. Just when I am on dark roads, when i flick on the highbeams, I want the lowbeams to stay on with the highbeams.
Old May 13, 2022 | 05:26 AM
RA030726's Avatar
I'm nutty for Nissans
Not true. Many cars have the low beams stay on when the high beams come on.
Old May 13, 2022 | 07:35 AM
dbaray's Avatar
Low beam
High beam
I want it like this. When high beams turn on the lows stay on in this photo. My case, the lows go off as i push the highs on.
Old May 13, 2022 | 10:32 AM
KP11520's Avatar
There is a mod using a Diode to keep both lit when switching to High Beams.
Where did you get your projectors and components? They must have something they can supply/sell or recommend. They know 9004 bulbs have 2 separate filaments and the switch and wiring is either and not both. US Maximas came with 9004s and not the 2 lamp setup installed now in your car and is wired for such.
Old May 13, 2022 | 10:52 AM
dbaray's Avatar
OOO i see. Do you have any pictures of how its done?
I had a builder do my headlights. Build was done by a shop called 818 retrofits and I am using his lighting that he has made by the same company Diode dynamics. I believe thats what they are called.
Old May 13, 2022 | 12:19 PM
RA030726's Avatar
What kind of wiring do you have now?
Old May 13, 2022 | 12:26 PM
dbaray's Avatar
no wiring was changed actually. Still the same factory harness, and i think he made the harness to plug in.
Old May 13, 2022 | 12:28 PM
dbaray's Avatar
I asked him about a diode and he said he uses 15amp diodes. The Projectors they use are 3.2 amps and the led bulb I have on my high beam is probably 2 amps. He stated its well below the 80 percent duty cycle of the diode 12 amps
Old May 13, 2022 | 07:29 PM
dbaray's Avatar
Update. The Diode solved the problem and now they all go on when I turn on my higbeams! Retrofits ftw
Old May 13, 2022 | 08:32 PM
I think that video legit had a thread linked to it where I explained the whole diode thing lol Super old vid! I had the fog lights rewired also so they wouldn’t shut off with the high beams either.
Glad to see you got it worked out.
Old May 13, 2022 | 08:43 PM
dbaray's Avatar
Yes the fogs actually stay on too with highbeams activated so it looks even cooler lol.
Old May 13, 2022 | 08:47 PM
dbaray's Avatar
Low beam
High beam
Old May 13, 2022 | 08:50 PM
dbaray's Avatar
Heres how its done in case anyone needs help.
Old May 14, 2022 | 12:09 PM
aq12's Avatar
Show us the front of your maxima during the day, im curious to see the final product
i want to do this mod but afraid it will look too ricey and out of place in a 28 year old car LOL
Old May 14, 2022 | 04:50 PM
dbaray's Avatar
ok ill show some pics.
Old May 14, 2022 | 05:00 PM
dbaray's Avatar
Old May 14, 2022 | 05:02 PM
dbaray's Avatar
IMO my car is stock and i make it look as good as I can, i havent lowered it or put a body kit on it b/c i like the original build. I break a lot of necks 😏
Old May 14, 2022 | 07:21 PM
aq12's Avatar
Thanks for sending the images, but man that looks so clean, love the tints on your car and final product
i might end up doing it myself with the smoked style instead
Old May 14, 2022 | 07:59 PM
How dark did you tint your windshield? I can see in maybe 5% in one of the pics....
Old May 14, 2022 | 10:47 PM
Zerodrag's Avatar
What low beam projectors are you using? I am surprised I do not see a defined cutoff on the tree in your pic. But it could just be the night shot not picking it up well.
Old May 25, 2022 | 11:18 PM
addie.'s Avatar
Name of diode
could you please link or tell us what diode we should be using, im installing projectors as well, thanks!
Old Aug 15, 2022 | 11:56 PM
dbaray's Avatar
lol late response; All windows are 5% and the front windshield is 15%, and I only have it to give the car the look I want and to keep my interior very cool in the hot heat. But before anyone does that on there windshield, I am a window tinter and the most I recommend for anyone is between 70% - 20% as 15% is Dark Dark You can check out my YouTube as I have videos of how it is 😀
dbaray's Avatar
i wish i could tell u! But he actually makes the diodes himself 🥲
Old Aug 16, 2022 | 12:07 AM
dbaray's Avatar
The projector is the actual LED built in. It’s a BiLED projector which are custom built by my builder 818Retrofits.
Old Aug 27, 2022 | 06:19 AM
mudassir.brandy's Avatar
Im sure its been answered before, just completed a full retrofit build on some R34 style headlights. Low beams work great but when i turn on the high beams, the low beams cut off and only the highbeams turn on, looks kind of weird when its just the highbeams on. Any way to solve this? Or is my headlight switch going bad.Speed Test
Thanx
Old Aug 27, 2022 | 07:21 AM
dbaray's Avatar
Well technically having high-beams on while driving can blind oncoming traffic. Especially on those roads with only 2 lanes ⬆️⬇️. As far as being illegal, U can have them on as long as u turn them off when traffic approaches your car I believe.
Old Aug 28, 2022 | 06:42 AM
1N4007. You’ll need two (one for each side)
alvarezm99
Mar 8, 2021 03:44 PM
NBD925
Dec 16, 2012 07:33 PM
BobMax
Sep 7, 2011 01:02 PM
