Fuel leaking from water separator (near carbon canister)
Old Aug 27, 2022 | 09:24 AM
Skyqua7's Avatar
Occasionally I'll have fuel leaking from behind my carbon canister...
I never overfuel but the fuel leak can happen regardless of how much fuel is in the car...
Things I've done so far...
  • Replaced carbon canister
  • Replaced Evap Canister vent control valve
  • Also tested (to see if air could flow thru) Evap canister purge control VALVE (front of car)
  • AND tested Evap canister purge control SOLENOID valve (it clicks when putting a power source to it)
All tests came out fine...
I attached a video of what it looks like here...
https://drive.google.com/file/d/1g2uTIXRx4TcCODozWOT1rxxULIdAepqa/view?usp=drivesdk
I also attached an image of where the water separator is...
Any suggestions would be greatly appreciated...
Old Sep 16, 2022 | 10:39 AM
95maxrider's Avatar
Lightly modded
It sounds like you've done your homework already. I'm guessing the hose is in good shape? Hose is cheap, it may be worth replacing it with a new one and see if there's any improvement.
notstreetlegal
Jan 9, 2013 01:25 PM
defiance
Sep 10, 2012 01:17 PM
KCMC582
Apr 26, 2005 05:51 AM
paralyse
Jan 4, 2005 04:28 PM
NYCe MaXiMa
Aug 22, 2001 07:54 PM
