Spilled Transmission Fluid in Engine Bay
Old 09-13-2022, 05:06 PM
mark217's Avatar
So I changed my transmission fluid today and while pouring the transmission fluid, the funnel fell over and I spilled a bit of fluid into the engine bay on the transmission side. The fluid got onto the transmission and also some hoses and plastic that are in the way. I drove the car and everything feels fine so far and most of the hoses and plastic have dried up. However, there are small puddles on the transmission itself. Is it ok if I leave it and let it dry by itself, or would it be necessary to degrease it? If so, can I use throttle body cleaner or mass air flow sensor cleaner to degrease it?
mark217 is offline
Old 09-14-2022, 11:02 AM
Turbobink's Avatar
How about just some dish soap (blue Dawn) and a hose?
Turbobink is offline
Old 09-14-2022, 05:28 PM
JvG
JvG's Avatar
I've had very good luck with that.
id just squirter an extra heavy dose of Dawn or similar dishwashing detergent in some water. Apply to your mess, then scrub. Rise off with clear water. Done.
JvG is offline
Old 09-16-2022, 10:34 AM
Lightly modded
95maxrider's Avatar
Trans fluid doesn't so much as dry up as much as it attracts dirt and becomes a messy sludge. Try to get as much of it up with a paper towel or rag, and then clean up the residue with some Dawn/soapy water. Brake cleaner would also work.
95maxrider is offline
mike.
11-26-2012 08:22 PM
kasemodz
07-04-2005 09:07 AM
xlu
05-05-2002 10:45 PM
superdesi
04-20-2001 06:03 AM
Quick Reply: Spilled Transmission Fluid in Engine Bay
