98 Automatic HVAC not changing modes
Old Sep 21, 2022 | 03:30 PM
reallywildstuff's Avatar
98 i30
Q -What’s wrong / what parts need replacing below? I never did replace the FRESH/RECIRC ACTUATOR on this, now it looks like there is something else to fix:
Previously: turn on HVAC & AUTO = A/C air blowing out top dash vent
Recently: air only comes out floor (?) at system start, definitely no air from top vents. If press MODE to cycle through the modes, and stop at “dash vents” = i can hear the mode doors changing, and then the air blows out the top as normal again. Then Press AUTO = no change (still working as normal).
Failure seems correleated to amount of time since system was last operated (minutes vs hours parked)…like the mode doors are holding their previous position for only so long before they give it up, and then <something> doesnt have enough gumption to force the change back through UNTIL modes are manually cycled…
TIA
BrianA
Planet Houston
Old Sep 30, 2022 | 07:04 AM
TTT...is this thing on?
after a week of sitting: I can no longer get air out of the top dash vents...”Mode” still moves Defrost On and the Off again but that’s about.
i need to run the debug procedure...but it seems I have another stepper motor out (in addition to the recirc door).
- “How many of these doors are there on the HVAC stack?”
Seems like since I’m already gonna be in there to replace two already I mightaswell do them all huh?
DISCLAIMER - I’ve had the replacement RECIRC motor on the shelf for -years-...
Old Sep 30, 2022 | 10:55 AM
RA030726's Avatar
I'm nutty for Nissans
There are 3 motors total.
Do you know about the diagnostic mode? The FSM has the procedure to test everything.
Old Oct 15, 2022 | 05:51 AM
Are the three model numbers of motors to replace already broken out somewhere?
i’ll start: the “Fresh/Recirc Actuator” (FSN term) is:
Part Number 27740-40U00
says “Actuator-Air” on the label
there are a GT of three motors total, correct?
meaning there are only two other Part Numbers to identify:
- Mode Control
- Temperature Blend
BrianA in Houston
Old Nov 20, 2022 | 01:16 PM
urb0123's Avatar
I have a similar problem. Is the FSM posted here? If this were my car, I would just buy the FSM. I'm fixing it for my ex father in law so I don't want to buy the FSM for a single use.
Old Nov 20, 2022 | 02:06 PM
urb0123's Avatar
Found one.
https://www.my4dsc.com/nissan-info/f...ervice-manual/
Old Nov 20, 2022 | 04:22 PM
urb0123's Avatar
Any luck on the Mode Control motor? I can't find it online for the life of me. Temperature blend motors are all over the place but the mode motor isn't coming up. It makes me wonder if I'm using the wrong terms for it.
gtp2k1
Oct 2, 2011 12:35 PM
Gemini67
Dec 5, 2006 02:40 PM
2kmaxima
Jun 5, 2005 12:42 PM
sk24iam
Jan 21, 2004 07:07 PM
azflat4
Aug 24, 2003 10:56 AM
