Stupid Addco!
Old 02-11-2002 | 01:43 PM
  #41
dwapenyi's Avatar
Oh. I see what you're saying. When I did mine, the instructions I downloaded (from VBmaxima, I think?) said that I would have to bend some things around to make them fit. I remember that the brackets I screwed in were so tight that the flat pieces actually bent in a little. The fit is real tight. That urethane bushing ain't going nowhere. It's great, and no squeaking or anything.
If there comes a time to take it off, I may be in trouble
DW
Originally posted by mozy
See what you guys dont understand is that my problem is with the curly bracker _/\_ not the flat brackets. I figured out that the U-bolt goes into the bracket with two oval holes. That was a simple "star shape goes into star hole" puzzle.
My problem is with the curly brackets that clip onto the urethan pieces on the bar.
none of the bolts ] or U fit into those brackets. The holes are spaced about 5mm too close ON ALL FOUR BRACKETS. and the whole bracket is made 5mm too short. basically the bolts overlap parts of the holes but dont go in. I was thinking about bending them apart but them Im worried that the bar's urethane piecs might slip out or something because they have inadequate grip from the bend brackets.
I'm getting more ****ed everyday now. This is not right, addco ****ed me over twice.
thanks for your support (I think?)
Old 02-11-2002 | 03:29 PM
  #42
mitch33x's Avatar
got my Addco from Cattman, installed in 30 mins, no problems...
CorollaULEV
30
08-09-2021 08:11 PM
pears
09-18-2015 05:25 AM
A32goldylocks
09-16-2015 01:33 PM
carlosvq30
08-17-2015 11:32 AM
TexMaximum
11-23-2000 03:50 PM
Quick Reply: Stupid Addco!
