Tachometer
Old Sep 10, 2023 | 03:11 PM
GreenBear's Avatar
Tachometer
I seriously think I am just out of luck here, but I am going to exhaust every option before I give up. Of course my tachometer quit working. Bought a parts car, only to find out it was technically a 98 model so the clusters don't match up. I have been to 2 junk yards, tried 2 separate clusters. Same problem. The motor for the needle is always shot. I can't find a working after market replacement. Is there another option or is this the one thing that can't be fixed?
Old Sep 11, 2023 | 02:57 AM
Rit's Avatar
Rit
What year and model maxima ?
Old Sep 11, 2023 | 09:33 AM
GreenBear's Avatar
Originally Posted by rit
what year and model maxima ?
1997 gle.
Old Sep 12, 2023 | 10:15 AM
95maxrider's Avatar
Lightly modded
Does the car run normally? To verify the ECU is sending a signal to the cluster (or at all) you may want to get a Bluetooth OBD2 code reader and hook it up to your OBD2 port, connect it to your phone, and use a free app like Torque to see if it's getting an RPM reading. If the app doesn't get an RPM reading, you may have a bigger problem on your hands. You may also want to inspect the wires for the connectors on the back of the cluster for any breaks or damage. I find it hard to believe that you've got three bad clusters in a row.
Old Sep 22, 2023 | 08:00 PM
Passima's Avatar
Have you checked with a rebuilder? As far as I know from looking to do mine; you'd also have to get those extra clusters reprogramed to your Vin/security system. My cluster dies randomly and the tach jumps around like a Honda rev boy. If it helps here is who I'm using for mine when I can take my car off the road https://atlantaspeedometer.com/Home/...0/Default.aspx ball park estimate for me was like $275
Old Sep 23, 2023 | 06:56 AM
Mark97SE's Avatar
If your interested I have a working 97 cluster (white face gauges) laying around I'd be willing to part with.....Or I could do just the tach if that's all you need.
Old Sep 23, 2023 | 09:35 AM
KP11520's Avatar
A member here has a lower mileage 97 (somewhere around 115K) Maxima that was rear ended and he's parting out. Maybe he'll ship it to you> I've bought parts from him.
https://maxima.org/forums/4th-genera...rting-out.html
Hope this helps!
But I suspect 95\maxrider might be onto something UPSTREAM possibly.
onyx10
Apr 14, 2008 07:51 AM
ILLeSt MaX
Mar 2, 2006 10:59 AM
GREGB287
Jul 22, 2005 06:35 AM
dr_jekyll
Oct 12, 2003 08:47 AM
Max240
Mar 12, 2003 08:29 PM
