96 Hard Starting Issue cold and warm
Old Feb 3, 2024 | 05:05 AM
Zuyder's Avatar
Hi I have a 96 and while it will start, it takes several attempts and seems to want to "catch" when I let off the key. Like, I crank it and then as soon as I go to let off it'll either start or almost start. It does this both cold and warmed up.
Once started the car runs fine.
Things done so far:
New NGK plugs (it needed them)
New air filter
New fuel filter
Old Feb 3, 2024 | 10:50 AM
Rit's Avatar
Rit
Posssible faulty ignition switch. Common problem. Maybe first try spraying some contact cleaner in the key slot.
Old Feb 4, 2024 | 12:12 PM
JvG's Avatar
JvG
The lock and ignition switch are separate.
Spraying contact cleaner into the switch does not solve this issue.
Replace the switch.
Old Feb 4, 2024 | 12:20 PM
Turbobink's Avatar
Sounds like bad starter/starter solenoid to me …
Old Feb 5, 2024 | 05:12 AM
Zuyder's Avatar
Am going to pull the switch and check it out. I will update as to what I find. There's a video by a boredmder that's pretty detailed.
Old Feb 26, 2024 | 09:46 AM
Maxbumpo's Avatar
I solved a 'hard start' issue on my '96 I30 by doing two things: Added more ground straps between the starter and the battery, and replaced the fuel regulator.
daniel.simmons
Mar 16, 2023 09:19 AM
il99max
Dec 16, 2009 09:37 AM
maxfanfromohio
May 4, 2005 06:13 PM
max4evr
37
Oct 19, 2003 07:40 PM
Mike S.
Dec 13, 2000 10:14 PM
