Need help with P1444 Evap Code
Old Aug 4, 2024 | 09:29 PM
Brian99max's Avatar
Hi I have a 99 maxima with a p1444 Evap code. It’s for Evap canister purge volume control valve circuit I’ve changed the purge valve and it didn’t fix the problem and the car is stalling out sometimes low RPMs. I’ve changed some other things that AutoZone recommended but none of those fixed it.
Old Aug 4, 2024 | 09:40 PM
mikepro1015's Avatar
sounds like you need a new charcoal canister, you could also have a blockage in a line but that is unlikely, new one from Autozone runs 200$
Old Aug 5, 2024 | 03:53 AM
Brian99max's Avatar
Thanks for the reply. I’ve already tried that and it didn’t work
Old Aug 5, 2024 | 05:24 PM
sounds like you need to check the rest of the system
Old Aug 5, 2024 | 06:12 PM
Brian99max's Avatar
I’ve checked and/or replaced everything else. Now the car stalls sometimes at low RPMs
Old Aug 5, 2024 | 06:14 PM
Time to look for a vacuum leak. Perform a smoke test.
Old Aug 5, 2024 | 06:15 PM
Brian99max's Avatar
Maybe a bad ecu. If it is and it’s giving false codes, will the car still have problems associated with that code?
Old Aug 5, 2024 | 07:45 PM
Brian99max's Avatar
Tried that also. But it was my first time and I’m thinking I didn’t do it right. I think it saw somewhere It said I had to have a certain valves closed or open or something like that. Going to figure that out and try it again.
David A
34
Sep 4, 2018 05:44 AM
atriuum
Dec 4, 2009 09:41 AM
MaximaMan
Jan 6, 2009 06:33 PM
sharabi
Nov 29, 2006 03:50 PM
Dubbya
Jan 18, 2006 01:11 PM
