Deflection specs on belts?
Well, I had my compressor & PS belts replaced. Now, they squeal on start-up, which I understand from reading other posts means the belts are probably too loose. Does anyone know the deflection specs for the belts?
Also, my mechanic said I needed a new tensioner pulley bolt (he probably damaged it). When you buy a replacement bolt does it comes with all the needed hardware (spacers, washers, nut)? I read in a post that you can buy kits to replace the belts- other than the belts and bolt(s), is there anything that I am missing? I want to make sure I have good hardware to minimize the noise.
Thanks!
'98 Maxima SE fully loaded
Thanks!
Belt Deflection is as follows:
Limit After Adjustment New
Alternator with A/C 7 4.2-4.6 3.8-4.1
Alternator w/o A/C 10 6.3-6.9 5.8-6.2
Power Steering 11 7.3-8.0 6.5-7.0
Applied pushing Force 10 Kg or 22 lbs
This is measured from the bottom of the car pushing upward on belt, pushing midway between pulleys.
That didn't format properly
There are three measurements
Limit, Deflectection after adjustment, Deflection of new belt.
The numbers below represent these three headings. The first number is a whole number ie 7,10, 11 the others are ranges.
jmlee44
Oct 2, 2022 02:13 PM
