Intake HELP!!!!!! Quick pleasssseee
Old May 30, 2002 | 06:56 PM
Redmax's Avatar
Redlinemax Owner
I am installing my stillen intake and the directions say to put the airflow sensor in the front of the intake but i don't see an airflow sensor!!!!! i have a 99 se limited did they not have a seperate sensor on this car?
Old May 30, 2002 | 06:58 PM
Jamsan's Avatar
are they talking about the adapter?
Old May 30, 2002 | 07:00 PM
gtr_rider's Avatar
192.168.1.1
Well when you remove the factory air box, in the rear of it closest to the MAF there was a little sensor that was plugged into it. Just move that sensor location to the front of the filter where the whole is already set, and plug it in.
Old May 30, 2002 | 07:05 PM
Redmax's Avatar
Redlinemax Owner
the only sensor i have is the one that plugs into the maf
Old May 30, 2002 | 07:07 PM
Jamsan's Avatar
same w/me
Old May 30, 2002 | 07:08 PM
Redmax's Avatar
Redlinemax Owner
actually i just looked at a pick of redmaxpa007's car and he doesn't have one in the front of the pop either. so i may be ok
Look
http://www.cardomain.com/id/redmaxpa007
Old May 30, 2002 | 07:18 PM
StygianMax's Avatar
Re: Intake HELP!!!!!! Quick pleasssseee
Check out this page: http://www.greghome.com/Greg's%20Gar...0High-Flow.htm
The pix/text are really good.
Old May 30, 2002 | 07:33 PM
sil SE's Avatar
mine is 98 and like yours i dont believe we need to do any replacing of sensors, the older max needed to attach that sensor to the filter or something like that
Old May 30, 2002 | 07:56 PM
gtr_rider's Avatar
192.168.1.1
I dont know about your maximas but there was a maxima ive seen with the stillen intake and it was a 97-99 and he had the insert hole in the front, but he did not place the sensor inside because "it blocked air going into the hole"
Old May 30, 2002 | 08:09 PM
Redmax's Avatar
Redlinemax Owner
yep no sensor I just took the car for a test drive and WOA MOMMA!! Sounds like a symphony is playing under the hood man o man makes ya wanna
Old May 30, 2002 | 09:13 PM
iregula's Avatar
yeh only MAF
Old May 30, 2002 | 09:29 PM
MaxedOut's Avatar
95-96 Maxima's had Air Tempature Sensors on the airbox.. You proabaly have a stillen intake for a 95-96...
since u have a 99 u dont need the sensor--- just tape up the whole and u will be all good
dont leave the whole at the end unplugged or unfiltered air will go into ur maf
Old May 30, 2002 | 09:43 PM
Kashoggio's Avatar
Old May 30, 2002 | 09:51 PM
StaindMaxima's Avatar
I have a 99 and I managed to track down the sensor you guys are talking about I think. It is the Ambient Air Temperature Sensor I believe, which I removed from the stock setup and plugged into the end of my Stillen pop charger, as stated in instructions. The sensor in its stock location I believe was in one of the plastic tubes down to the engine side of the stock airbox, plugged in to the firewall side. I had a 97 and it had the sensor present also. I would think they all have them, but I cannot say for sure. My Haynes manual covers the whole 4th gen and doesn't note it being optional on some years/models.
Old May 30, 2002 | 09:53 PM
Oh yeah, and if you do manage to find the sensor, be sure to take the rubber grommet it sits in on the factory tube. You will need it to plug into the Stillen unit.
Old May 31, 2002 | 11:32 AM
Kevlo911's Avatar
Kevlo for President
in my 97 i have a sensor in the very end of the ram intake stock tub, it is right before the bottom part of the stock airbox
Old May 31, 2002 | 11:36 AM
Jamsan's Avatar
ah yes ...i know what you speaketh of now....on the end of the scoop thingie....all i did was take out the attachment that was in the stock tubing, plugged it into the sensor, and let it hang there...then my car died, and i thought it was because of that (after changing fuel filter)....i had been driving around and it just died..so i put it back on
Old May 31, 2002 | 01:03 PM
GATORS1's Avatar
My 98 had the sensor towards the bottom of the stock airbox next to the MAF. I just had to pull it out and it plugged right into my pr cai.
Old May 31, 2002 | 01:52 PM
Krash513's Avatar
I have a 97 and had the ambient air temp sensor plugged into the top of the stillen intake. BUT BOY WAS I ripped when i got the PR hybrid setup and realized that the sensor now had to plug into the pipe. Was a ***** to find a cork to put in the end of the intake, but it works great now
JakeOfAllTrades
Oct 5, 2015 10:40 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
