pr cai install - PLEASE HELP ME
Old Jun 14, 2002 | 07:23 PM
danw2481's Avatar
i just installed my cai - i have a few questions 1- i have an extra hose that looks like it should connect to the upper cai tube but it has nowhere to go 2 - my car is idling below 500 and very rough and it kleeps stalling everytime i stop - i need help desperatly
Old Jun 14, 2002 | 07:44 PM
danw2481's Avatar
bump - anyone please i really need this to work right
Old Jun 14, 2002 | 08:23 PM
Jamsan's Avatar
its most likely the IAC valve....the little thin wire that comes from just under the throttle body...it has 3 valves i believe....just get the hose from there and plug it into the upper pieces ....should have a slot for it....probably jut a long thin metal piece that sticks outs....just slide it onto there
Old Jun 14, 2002 | 08:47 PM
danw2481's Avatar
i connected al the hoses to the upper intake tube but there is still a small hose left near the valve cover
Old Jun 14, 2002 | 09:15 PM
RedMax95's Avatar
there should have only been 3 hoses involved, there is one hose that acts more as a breather and doesnt connect to anything
Old Jun 15, 2002 | 12:27 AM
Nismo's Avatar
I believe that hose your talking about is your transmission breather hose which just hangs there next to the crankcase breather hose. I would check to see if all hoses and sensors are pluged in all the way and also resetting the ECU might help. When you took off your stock intake, did you check to see if your throttle body was dirty or not?
Old Jun 15, 2002 | 07:57 AM
JAIMECBR900's Avatar
The vent hose you are mentioning is for the tranny and will not cause the car to act the way described. It seems to me that the big vaccum hose towards the rear firewall is more likely the culprit. It is a big vaccum hose that goes connected to one of the pre-made tubes on the upper CAI tube near the TB. It goes connected to a controller behind the TB. If this comes loose or is kinked, the car will not idle and die everytime. When I installed my PR CAI, it did not reach properly and I MADE IT fit and one day it just popped loose. My car died at every stop light on the way home. I replaced that hose only with a longer one (pain because I just went to the auto parts and started trying on different hoses from the wall until one fit correctly) and the car never died again.
Old Jun 15, 2002 | 08:13 AM
BIGMAX's Avatar
I had the stalling problem when I installed my CAI.
I kept rechecking all the hoses and everything, but the problem persisted. The next day I checked again and realized that there was a sensor that plugged into the underside of the pipe that didn't see and had forgotten. Once I plugged it in the problem went away.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
