SARD FPR Install Questions...
Old Jun 20, 2002 | 06:58 AM
ejj's Avatar
ejj
Thanks to Thomas (sx7r) I just got my SARD FPR in the mail yesterday. Seems to be a high quality unit.
Install questions...
The thing comes with nice looking instructions, if you can read Chinese and/or Japanese, which I can't. The port on top is obviously the vacuum port. Which is which with the other two.
Is the hex type plug on the side just a plug for the test port? How do you adjust it? Does it have something to do with the height of the vacuum port on the top?
Old Jun 20, 2002 | 07:03 AM
ejj's Avatar
ejj
http://photos.imageevent.com/1max2nv...e/Dcp00996.jpg
Just found this pic that Tony took a while back. So, the plugged hole is the test port, but which is which with the other two?
Old Jun 20, 2002 | 08:27 AM
ejj's Avatar
ejj
Okay, I was thinking about it...the one on bottom has to be fuel intake, and in front (looking at the pic above) has to be out...right?
How about adjustment procedure?
Old Jun 20, 2002 | 09:17 AM
Chunger's Avatar
My other car is a Hybrid
Output to return line is below... fuel rail side is side port.
I'm about ready to instll mine too... just gotta find a good mounting location.
Adjustment is the nut on the vacuum stud area.
Old Jun 20, 2002 | 09:33 AM
ejj's Avatar
ejj
Cool, thanks. That's what I though.
Now, moving the nut itself doesn't appear to do anything. Isn't that nut just a locking nut? Do you screw the vacuum port in and out to adjust it?
Old Jun 20, 2002 | 09:55 AM
BriGuyMax's Avatar
ok...now this can get a little confusing since the fuel flows the OPPOSITE way that most people think...it goes to the FRONT rail first...THEN to the back rain...then throuh the stock regulator..and then to the return line (fuel line coming off the stock FPR)
you want to install it so that the bottom on the SARD goes to the return line...and the side port goes to the fuel rail where the stock FPR was.
Fuel pressure adjustment is achieved by loosening the 13mm lock nut and then moving the vaccuum port stack up and down with the 10mm part. If you turn it counter-clockwise (loosen) then fuel pressure will drop...if you turn it clockwise (tighten), fuel pressure will rise. You'll only need to turn it small amounts to get results as it is very sensitive.
Old Jun 20, 2002 | 10:34 AM
ejj's Avatar
ejj
Thanks! That clears just about everything up for me.
Old Jun 20, 2002 | 12:23 PM
1MAX2NV's Avatar
I have been looking around and there is not a perfect place to put it. Only place I can find is by the begining of the uppper water neck. I'm going to use a metal bracket and mount it to the bolt that holds the tranny dip stick.
Old Jun 20, 2002 | 12:40 PM
Jime's Avatar
I put mine on the other side of the throttle body just above the fuel filter. If you look at my N20 Setup Pic in my signature you can see where it is. I didn't want it stuck out where everyone can see it. My whole setup for nitrous is pretty well completely hidden unless you know what you are looking for. Some people want all the folks to see what they have and that is fine too.
BTW the Sard is a great FPR, very easy to adjust and stays where you set it, can't ask for more.
Old Jun 20, 2002 | 02:46 PM
sx7r's Avatar
glad they worked out for you guys.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
