Brake light
Old Jun 24, 2002 | 07:56 PM
mipinc's Avatar
Brake light
My break light is on all the time. The oil level is close to max. How can I check the hand break switch and fluid level sensor?
Old Jun 24, 2002 | 09:11 PM
nadir_s's Avatar
vicodin ... gift of life
pads?
It could be ure brake pads...
Although i'm not sure if the brake light will turn on for that... i know it did for my celica so i'm assuming the Maxima has that feature as well.
Old Jun 25, 2002 | 07:18 AM
erty67's Avatar
Decal Specialist
I'm sure you've tried the obvious, but if you didn't make sure your E-brake is all the way down. In most cars if it's pulled up even one notch, the light may come on. Just a thought....
Old Jun 25, 2002 | 07:48 AM
elcid's Avatar
Try your brake light switch also, make sure it's not stuck. It's the little switch that goes in and out as you apply pressure to the brake. My brake lights used to not work, and then I spayed soem cleaner in there and it worked again. Just follow your brake up and you'll see the litle switch
Old Jun 25, 2002 | 08:23 AM
mipinc's Avatar
The light came on in a cold weather and then went away. Now it is back and on all the time. Hand break is completely down and the switch is going in and out just fine. It is not stuck. How could the break pad turn that light ON?
Old Jun 25, 2002 | 08:36 AM
elcid's Avatar
Sorry mna no clue regarding the brake pads. Try removing your fuse and putting it back in, or disconnect your battery for a while mayeb the lights are siezed up.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
