Trunk light
Old Jun 28, 2002 | 04:31 PM
JP73
Trunk light
My trunk light doesn't work and I just put a new bulb in. Is there a fuse for this light and if so, does anyone know which fuse it is? Also, where is the button that causes the light to turn on and off?(what I mean is a button that comes into contact with the trunk when it is closed like on your refrigerator) Thanks in advance.
Old Jun 28, 2002 | 06:50 PM
Speebs's Avatar
I aim to misbehave.
I have the same problem! I asked about a year ago but nobody responded. does anyone know the answer?
Old Jun 28, 2002 | 06:51 PM
nadir_s's Avatar
vicodin ... gift of life
Re: Trunk light
I'm sure all the interior bulbs (dome light, door lights, trunks lights, etc.) is on the same circuit w/ one fuse...
Kk, i ran out to check it for u. I see a red wire connected on the top trunk hinge. the bottom hinge (connected to the fender) only has the trunk unlock switch. So yea, check the red wire. I looked at the fuse box.... it could be the one labeled "ELEC PARTS" or perhaps its connected to the "TAILLIGHTS" or the "STOPLIGHT". sorry, i'm not sure, just check em all. well good luck.
btw- i have a 96 SE... just incase if its a diff setup on a diff year
Old Jun 28, 2002 | 08:00 PM
MIXXMAX's Avatar
There is a "tilt switch" on the left side of the trunk underneath the rear deck. Here is where the left hinge of the trunk meets the switch in turning the light on and off. Sometimes this switch "sticks" after a while. Just lube it with die-electric grease and you'll be fine. The fuse for the trunk light is connected to the circuit marked "elec parts", I believe. It has a 7.5 fuse rating. If you pull this out, the interior dome lights and step lights on the doors should go out. This will also turn the trunk light off.
Old Jun 28, 2002 | 08:08 PM
JP73
Thanks. I'll check it out.
Old Jun 28, 2002 | 08:23 PM
Speebs's Avatar
I aim to misbehave.
yes, thank you!! I will check it out.
fastcarny
Oct 6, 2015 10:42 AM
rnb754
Sep 14, 2015 11:39 PM
Maxima30
Sep 7, 2015 06:13 PM
rbaker100
Sep 6, 2015 02:46 PM
Hailstatejig
Sep 2, 2015 06:52 AM
