Lights turn on, radio etc. but not starter... help?!
Old Jun 28, 2002 | 08:08 PM
Miasma's Avatar
Ok, this happened to me last year too, so i am concerned that something is causing my batteries to die.
I am able to get power from the battery, I can turn on headlights, radio, everything that runs off the battery, but the starter will not engage. If i let some jumper cables charge the battery for about 5 min from another car, it starts ok. I am pretty sure the battery is dead, but if not, what else could it be and why does it keep causing my batteries to die?
btw, once the car is started, it runs fine, so i am pretty sure it is not the alternator...
Old Jun 28, 2002 | 08:24 PM
MIXXMAX's Avatar
Re: Lights turn on, radio etc. but not starter... help?!
It could be the starter. Our 4th generations are proned to have bad starters. The solenoid tends to "stick" all the time.
Old Jun 28, 2002 | 08:37 PM
Miasma's Avatar
well, i hear a tick when i turn the key to ignigion (just one, not many ticks) so i think the solenoid is engaging, but i am not 100% sure what the tick is, the starter does not engage though.
Old Jun 29, 2002 | 08:22 PM
MIXXMAX's Avatar
"Joggle" the key while trying to start the ignition. The "ticking" you're hearing is the solenoid "sticking". It is not turning. Joggling the key sometimes "frees" it up.
Old Jun 29, 2002 | 08:44 PM
nadir_s's Avatar
vicodin ... gift of life
EXACT problem my celica has. I replaced the starter and after about 9 months, the problem came back. Funny thing about this problem was it wasn't only the starter that had the problem... i had an aftermarket alarm system. The alarm system connected to the starter wires so that it would cut the power to the alarm in some relay when the alarm was on. So... the mechanic said it was a starter problem... even tho it would start IMMEDIATELY when jumped. He replaced the starter and guess what... CLICK CLICK... the new starter still clicked!! Then what we did was wire a starter button directly to the starter (u turn key into ignition and press button) and VOILA the car started immediately. I'm guessing the alarm's starter relay was bad? It was affected when outside temp was hot.
9 months later (now) the car has begun its *clicking* disease. This problem only happens its hot underneath the hood (hot summer day, or car was driven for long period of time). I'm not sure what's up w/ the car. My brother drives my old car now and i feel hecka bad because its summer and the freakin starter isn't working. It does turn on after several *joggles* (press starter button continuously till it starts to turn the engine).
Old Jun 29, 2002 | 10:31 PM
Miasma's Avatar
well, i ended up replacing the starter, i dont think my prob is the same as your celica, i just got one tick and know it was not the alarm (factory alarm has starter interrupt but i just know it was not the prob).
anyway, i am getting my real alarm installed on tues
thanks guys!
tsi6001
Oct 3, 2022 10:23 PM
vingodine
45
May 21, 2016 12:46 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
MikesChevelle
Aug 9, 2015 11:50 AM
