Need some advise on subwoofers for my '96 MAX.
Old Jun 29, 2002 | 11:31 AM
cyrus2k1nyc's Avatar
I have the BOSE System on my '96 Max, but would like to add a sub or couple to it. I'm not sure which sub would be ideal for this BOSE System. I'm not sure which size I should get and the ideal wattage for it. Or should I need to change the CD Reciever? If so, which CD Reciever? What is the differece between those 2-4-8-ohm? Some even has dual ohms, does it performs better? And hope to get some nice advises from all ya bass-lovers. Thanks!
Old Jun 29, 2002 | 01:28 PM
iregula's Avatar
get one 12 inch in a sealed bbox....save space and sounds better than 2 10's
Old Jun 29, 2002 | 01:35 PM
nadir_s's Avatar
vicodin ... gift of life
If you were to add subs, i believe u have to change the amp too...
I have 2 12's JL subs in the box sittin in my room. I wanted to add those to the maxima but i think i need amps or whatnot. I can't just hook em up straight to the BOSE amp right?
Old Jun 29, 2002 | 01:49 PM
JMAXIMA's Avatar
no, you can't hook up your subs directly to your Bose system. the Bose system is 1 ohm while most car audio is 4 ohm. this would mean you would fry your Bose amps. but what you can do, not the best sound though, is to buy an amp with line in capabilities. you would get the signal from the amps, but not the power. your best bet is just to replace everything... head unit, component speakers (front and rear), and buy a couple of amps for your new components and sub(s). as far as recomendations for subs... its really up to you and what kind of music you listen too. for deep bass, a 12 would be good in about a 1.5 sq/ft box... give or take some depending on the sub. if you like tight, hard hitting bass, i like 10's for that. JL Audio are great subs... so are Boston Acustics... but they are both a bit pricey.
Old Jun 29, 2002 | 02:12 PM
nadir_s's Avatar
Thanks for the input. I read the faq and all... still wasn't clear about how the Bose system works but ure explanation helped.
Oh well, i like the Bose system... don't wanna mess aroudn w/ audio. My older car had the best audio setup and i wasn't too dissapointed w/ my maxima's system. I can live with it =)
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
sliptap
Sep 30, 2015 05:57 AM
Noela
Sep 26, 2015 08:22 AM
