Throttle Cable
Old Jul 1, 2002 | 12:46 PM
eelcram's Avatar
Throttle Cable
Can somebody tell me how hard it is to replace the throttle cable? It seems that my max is not accelerating as well when I hit the gas and found that the cable was bit loose. Thanks for the help.
Old Jul 1, 2002 | 02:55 PM
sinewave's Avatar
I would suggest that you lube and adjust it; I wouldn't change it unless it was broken or frayed. To adjust, loosen the lock nut and tighten the other nut until the throttle body butterfly begins to move. Back off on the nut 1-1/2 turns, then tighten the lock nut.
Old Jul 1, 2002 | 06:14 PM
TurDz's Avatar
It is very easy to tighten. But be sure not to overtighten it. There should still be some slack when you push it up and down. Feel how tight your cruise control cable is, and try to match that.
Also, I doubt you're looking in the right area. Are you saying you have problems with accelerating, possibly downshifting? If yes, then that's another issue.
Old Jul 2, 2002 | 07:00 AM
Yossarian's Avatar
anybody know the story with teflon-lined throttle cables? better pedal feel?
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Oct 24, 2015 08:05 AM
sliptap
Sep 30, 2015 05:57 AM
pktaske
Sep 4, 2015 08:40 AM
