My weekend project.
Old Jul 19, 2002 | 05:32 AM
Tallyman's Avatar
My weekend project.
This weekend I will finally be installing my eibach springs, painting the calipers red, and doing any other misc undercoating that I see as needed. I am wondering if anyone has had any issues, or pointers in the install. I am pretty competent when it comes to cars. I just stripped my 88 tbirb turbocoupe and put a gt-40 5.0 in it with 350hp. Anyway, just looking for some pointers if neeeded. Also, any special tools required ??? I do have tons of tools so I am sure I have it if I need one. Oh, this will be on a 2k2 6spd. Thanks.
STEVE
Old Jul 19, 2002 | 06:55 AM
[maxi-overdose]'s Avatar
Re: My weekend project.
STEVE
I am getting my eibach and koni installed this weekend too...well, by a mechanic
eibach is a direct fit with stock struts so u should be fine
have fun!
Old Jul 19, 2002 | 07:45 AM
maximadriven's Avatar
Re: Re: My weekend project.
have fun!
overdose, do you mind me asking how much your install is costing? I want to do the same install but I havent been able to find someone to do it for less than 450.00...
Old Jul 19, 2002 | 08:10 AM
soundmike's Avatar
Very sound, Mike
For spring install it'll average between $125-$200 with the front-end alignment included.
Old Jul 19, 2002 | 08:11 AM
Re: Re: Re: My weekend project.
for this shocks and spring setup, a forum member, also a mechanic, will do it for me for 120. that's a very good deal for me b/c front koni needs to be modified and fit into stock strust.
I think you are asking the shop to do it....if u know a mechanic there....ask him if he wants to do a side job.
Old Jul 19, 2002 | 08:49 AM
TellschMax02's Avatar
Socket set
Torque Wrench
Breaker Bar
Spring Compressor
Those are the basics. The fronts are easy - no gotchas there.
Rears are a little tricky. There is a metal plate covering the top of the strut tower. I used a deep well socket attached to a 4" extension attached to a universal joint. It worked really well. I was even able to get a torque wrench on it.
Good luck - let me know if you run into any issues. I have done this job 3 times already.
Brian
Old Jul 19, 2002 | 11:33 AM
Tallyman's Avatar
Originally posted by TellschMax02
Socket set
Torque Wrench
Breaker Bar
Spring Compressor
Brian
Cool thanks Brian
Old Jul 19, 2002 | 01:59 PM
MichaelAE's Avatar
You don't really want to get the alignment right away though. You really want to let the springs settle first, don't you?
Old Jul 19, 2002 | 02:01 PM
Tallyman's Avatar
Yep, that is my intention. Probably drive around town for a couple hundred miles.
Old Jul 19, 2002 | 02:04 PM
soundmike's Avatar
Very sound, Mike
Of course. I was just answering his question
Old Jul 22, 2002 | 05:01 AM
Tallyman's Avatar
Well all is installed and well. Took 3hrs, with me and my friend. We also painted the calipers and I went under the car with a can of undercoating to spray and bare metal areas. Let me say there are quite a bit, nissan is a little skimpy in spots. Anyway, spring install went fine, trimming the bump stops was the only retarded thing. I wish the springs would just come with new ones that are the right size. Oh-well, it looks awesome. It does ride pretty much the same, very slightly stiffer, but I kept the stock struts. I love it. I will try and get pics up soon...
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
Excalibur23
Oct 13, 2015 04:33 PM
sliptap
Sep 30, 2015 05:57 AM
