Microfilter: how much to replace and do you need to?
Old Dec 10, 2000 | 06:44 PM
sentient
I am getting a car with the in-cabin microfilter, which I didn't actually want but it came with the car. Three questions:
1. How much does it cost to replace? a) the filter itself, b) with labor, etc at a dealer
2. How easy is it to replace, or do most people take it to the dealer?
3. After the 6 months or year when we are recommended to change it, can we simply remove the filter and not put a new one in?
thanks, sentient.
Old Dec 10, 2000 | 08:31 PM
Deven2kStickMax's Avatar
Micro-filter for 2K Max
Yes you have to replace it at least twice a year. I just ordered mine from courtesy nissan. They have them for $40-something bucks. It's easy to install, just remove the battery and it's right below the battery. Hope this helps........
Old Dec 10, 2000 | 08:38 PM
tomz17's Avatar
Re: Micro-filter for 2K Max
Mine doesn't have one... So I assume you could just NOT put another one in after 6 months... (although, if you have allergies, it might be a smart idea to put one in for the spring)
Old Dec 10, 2000 | 09:15 PM
hawaiihs's Avatar
Re: Re: Micro-filter for 2K Max
The microfilter is for allergies or something?
How much does it cost to get it replaced?
Sorry, I am still new to all this.
Old Dec 10, 2000 | 09:42 PM
TimW's Avatar
The silent but deadly Moderator
its your
standard charcoal charged filter. there are instuctions in the box. not hard. awkward but not hard.
I'm waiting til 12 months to replace mine.
Old Dec 11, 2000 | 04:38 AM
wht2kmax
[QUOTE]Originally posted by sentient
[I]I am getting a car with the in-cabin microfilter, which I didn't actually want but it came with the car. Three questions:
thanks, sentient.
MY car didnt came with one, but I had one installed. I live in NYC so there is a good amount of smog everywhere!! I can tell you, it does work!! It removes about 80% of the odor that comes through the vents, only under extreme conditions
ex: tailgating a bus would you smell some exhaust fume. It cost me about 40 bucks for the filter, if you install it yourself, it will take about 30 min or so. $20 if you take it to a shop.
F/S Philip H4 HID Kit
00 Maxima SE A/T with 2% secret sauce
Old Dec 11, 2000 | 05:24 AM
MI2KSE's Avatar
Behind the glove box
Contrary to one of the earlier posts, the microfilter is installed/replaced by removing the glove box in front of the passenger seat.
Old Dec 11, 2000 | 07:57 AM
sentient
What nissan dealer service said...
I called a nissan dealer service dept and asked my questions. He said, no I wouldn't even try myself to take off the glove box, and yes if it comes installed from the factory with one, you need to have a filter installed at all times, and the cost is $150 ($48.95 parts plus labor) for them to replace it, but he wouldn't change it until 30,000 miles (not 7500 or whatever).
However what I don't understand is $42 is the invoice price for the factory install of the microfilter, so this leads me to believe they don't install any other special equipment, and thus you should be able to operate without a filter, if we choose just to discard the old one and not replace it. Anyone have any insight into this?
Old Dec 11, 2000 | 08:27 AM
TimW's Avatar
what a lying sack of dung (dealer)...
$150!!!!! Scam!!! And NO, the car is delivered without a filter, so it cant be required. Its up to you if you want it.
yes, dropping the glove box isnt everyone's cup of tea. But I can follow directions, and good ones come with the filters. It clearly tells you what to be careful of. I did it in 15 mins.. not sure where 100 in labor comes from. Also, the dealer is supposed to charge 30 mins for that, so they are padding that too.
I hate hearing that crap...
Old Dec 11, 2000 | 08:29 AM
TimW's Avatar
here..
read the instructions yourself... (look for the instructions link)
courtesy of Courtesy!
http://www.courtesyparts.com/onlines...3_acc_interior
Save a few bucks and buy them at Courtesy while you are at it.
Old Dec 12, 2000 | 05:14 PM
ohboiya's Avatar
whoa .. can we start @ the beginning?
1. Does my Y2K SE come stock with this?
2. What again does it do? Filter the incoming air from the outside?
Tkx!
Old Dec 12, 2000 | 05:53 PM
TimW's Avatar
sorry.. but $150 for this is just
excessive! I just hate to hear the dealer telling people that.
1. No, its not stock.
2. it filters incoming air. Its not HEPA, its charcoal charged. It filters out some pollens and cuts most odors (from the charcoal.)
Follow that link above. they have a diagram of how it works and install instructions to boot.
Old Dec 15, 2000 | 09:08 AM
MI2KSE's Avatar
Re: whoa .. can we start @ the beginning?
Tkx!
It's an option - if it's listed on your sticker, then you have it (you should also have a sticker inside the glove box letting you know when to replace it).
It's an activated charcoal filter for the hvac system...
Old Dec 15, 2000 | 12:17 PM
Max_Gator's Avatar
Just so I am clear, the car does not come stock with the actual charcoal filter BUT that filter can be put in any car. That is, you don't have to buy anything aside from the $44.00 charcoal filter. Right?
Old Dec 15, 2000 | 01:04 PM
MI2KSE's Avatar
It's an option. My wife's car came with it from the factory, mine didn't.
Nothing to buy except the filter...
Old Dec 15, 2000 | 02:29 PM
sentient
so my main question is...
If you've ordered one from the factory with a filter, is there no problem with at some point removing that filter, and not installing a new one. I would assume it would be as if you've never installed one in the first place. I know with electrostatic filters, for example, I don't think you can operate the system without the filter installed. If this is a completely passive system, then I guess it doesn't matter.
Old Dec 15, 2000 | 02:37 PM
dlee27's Avatar
I'm sure there will be no problem without microfilter. It's just carbon filter (yes, passive).
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
cruce91
Sep 20, 2015 10:23 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
