2k2 owners that have appld the HOOD VIB PK themselves
You guys that applied their own hood vib pack..
Are you finding that you only added the stopper and headlight pack and the problem was solved?
Did anyone need to do the adhesive procedure?
Re: 2k2 owners that have appld the HOOD VIB PK themselves
Re: Re: 2k2 owners that have appld the HOOD VIB PK themselves
Originally posted by GimmeTorq
Yep, that's all I did. I also visually inspected the hood alignment but it looked ok.
Yeah my hood looks good too. Aligned fine, feels latched solidly...was gonna order the pack from daveb and NOT go to the dealer. THX
Re: Re: Re: 2k2 owners that have appld the HOOD VIB PK themselves
Re: Re: Re: Re: 2k2 owners that have appld the HOOD VIB PK themselves
Originally posted by mykmar10
What is the hood vib pack?
I only ordered and installed the rubber hood bumper, and the headlight packs.
Re: Re: Re: Re: Re: 2k2 owners that have appld the HOOD VIB PK themselves
Basically the parts listed in this TSB
Worked for you? Rock solid?
Re: Re: Re: Re: Re: Re: 2k2 owners that have appld the HOOD VIB PK themselves
Are you finding that you only added the stopper and headlight pack and the problem was solved?Did anyone need to do the adhesive procedure?
Is the vibe pack something I have to buy and install myself or is it a dealer repair? I have had My 2K3 SE for only three weeks.
mykmar10,
It couldbe covered by warranty, I just hate taking it to the dealer...letting them order parts, having to go back again. What a hassle!! For a $20 fix, I'll pay and do it in 5 min.
You may not even have this issue...I only have it at 70+ in a strong headwind.
ARFF
how fast
do you need to go before you can see (or hear) the vibration? I typically go 80 and have hit 110 without seeing anything so perhaps my car is just good already. Thanks in advance.
Re: how fast
You're good then...
I have a 2002 SE that I just bought in May.
After reading the TSB and noticing the hood flutter, I decided to try getting the parts and installing. Before ordering parts, I looked under the hood to get an idea how much trouble removing the hood shield would be, in case I tried applying the hood adhesive myself. Then I noticed, there are rubber strips stuck to the top of the hood, right where the headlamp packs should be, and the hood stop is installed. Anyway I'm not sure why they were glued to the underside of the hood instead of on the lights, as the TSB states. One of the strips is longer than the other, and it is on the left side of the hood (if you are facing the engine), is this correct? Are the strips you get in the headlamp packs the same length?
Did anyone else with a newer 2002 come from the dealer with the strips stuck under the hood, or is it just my dealer being creative in installing the TSB fix?
TallTom
57
Oct 14, 2025 05:16 PM
AaronL
Aug 8, 2020 10:31 AM
