Installed New Speakers...
Old Sep 23, 2002 | 09:15 PM
SoloMaxima
i just installed new speakers...6 1/2" in the front and 5 1/4" in the back...fits nicely...front and back are the polk audio..GXR
i used the scorse Toyota 2000 and up speaker brackets and it fits nicely...two of the three holes lines up perfectly with the door...the other hole..i just stick a piece of napkin between the brakcet and the door to make it tight...
i got one question though....i had to splice into the speaker wires...what are the chances that the wires will come loose..??
Old Sep 23, 2002 | 09:34 PM
asu174's Avatar
Clay Aiken has fancy genitals
Re: Installed New Speakers...
I'll give the napkin 2 weeks before it falls out and it starts rattling.....
What kind of connector did you use? If you used the simple, clear ones and a good set of crimps, then you will be fine. I actually prefer to cut the wires than use the factory speaker harnesses.
Did you make sure the speakers are all in phase (positive/negatives lined up correctly for EACH speaker)?
Old Sep 23, 2002 | 10:33 PM
SoloMaxima
Re: Re: Installed New Speakers...
on the factory bracket it has three screws...but the bracket i used only has two holes that line up with the holes on the door...so i only used two screws to tighten it...and its really tight...it doesn't move around...
Old Sep 24, 2002 | 06:55 AM
Igor911's Avatar
Re: Re: Re: Installed New Speakers...
Why didnt you just modify the brakets from the stock speakers like i did? Simple and easy. All i did was rip out those cheapy cone speakers.
Old Sep 24, 2002 | 07:05 AM
Sprint's Avatar
why would you put smaller speakers in the rear
Old Sep 24, 2002 | 07:14 AM
pjonkheer's Avatar
Did you change anything other than your speakers? If you only changed out the speakers, does it sound any better? The reason I ask is, I would love to improve the sound of my system without spending much money on a new head unit, amps, etc...
Old Sep 24, 2002 | 08:33 AM
SoloMaxima
i did modify the stock brackets..but it was easier just to use the brackets i got...
i used 5 1/4" in the back because a lot of ppl on this forum was telling me that 6 1/2" would be too big to fit in the back...
i only changed out the speakers...it made a lot of difference..the stock speakers are made of paper...
Old Sep 24, 2002 | 08:36 AM
Igor911's Avatar
Whoever told u that 6 1/2" dont fit in the back is full of ****. LOL! That is the funniest thing i have heard. You can go as big as 6 3/4" all around the car. I found that with the after-market brackets, you would need to drill the door itself! That i was not going to do so i just modded the factory equiptment. My install looks professionally done and flawless of errors
Old Sep 24, 2002 | 09:03 AM
Vadim's Avatar
without modding it won't fit. I bet if you try, you can get a 10" to fit in the doors
Old Sep 24, 2002 | 11:08 AM
Igor911's Avatar
What modding??? The factory size is 6 1/2"!!!
Old Sep 24, 2002 | 11:32 AM
asu174's Avatar
5th gen with Bose:
Front: 6 3/4
Rear: 5 1/4
5th gen NON-Bose:
Front: 6 1/2
Rear: 6 1/2
You MUST mod a 6 1/2 to fit the Bose system or else it won't be big enough.
Old Sep 24, 2002 | 11:45 AM
Maxima91
POLK AUDIO y polk, there are many other better brands, arent those cheapys
Old Sep 24, 2002 | 11:51 AM
WildmanAL's Avatar
Why didn't you just use the brackets that were in there. I got 6 1/2 speakers in both front and back. I left the original clips on the ends of the wire and the original clip on the speaker. So if I want to go buy some stocks to put back in I can just snap the wires together and it looks stock.
Old Sep 24, 2002 | 12:04 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Crutchfield says for the 00-02
I know they can't always be right, but at least you can send them back if they don't fit.
Front Door:
6-3/4", depth up to 2-3/8", and a height up to 1-7/16" will fit.
Rear Door:
6-3/4", depth up to 3-15/16", and a height up to 1-7/16" will fit.
Anyone try fitting the Infinity Kappa 652.5i in the FRONT doors? It's got a 2-7/16" depth. I mean 1/16" can be had with a spacer right?
Otherwise, I'm going to get Kenwoods' KFC-Xr701. Any opinions on which is better? I'm partial to Kenwood Excelon, but my sub is Infinity and I usually try to keep at least all the speakers the same brand.
SPECS:
--Sensitivity 90 dB
--Freq. Response 45-21K Hz
--Recommended Power(RMS) 2-75 watts
--Peak Power Handling(RMS) 225 watts
Kenwood Excelon KFC-Xr701
--Sensitivity 92 dB
--Freq. Response 30-70K Hz
--Recommended Power(RMS) 2-50 watts
--Peak Power Handling(RMS) 200 watts
Old Sep 24, 2002 | 03:17 PM
Triple8Sol's Avatar
I miss the .org!
Infinity. I had some, they sounded bomb...
Old Sep 24, 2002 | 04:26 PM
asu174's Avatar
Re: Crutchfield says for the 00-02
Front Door:
Rear Door:
Go to www.crutchfield.com (NOT the magazine). You will have to choose Bose or no Bose. The correct sizing is what I listed above.
Old Sep 24, 2002 | 08:47 PM
SoloMaxima
Polks aren't cheapys...they are up there with the tops brands such as infinitys...
the polks i got are really nice...just ask anyone
Old Sep 24, 2002 | 08:51 PM
asu174's Avatar
Polk makes an excellent speaker. Among the best.
Old Sep 24, 2002 | 08:56 PM
SoloMaxima
Re: Re: Re: Re: Installed New Speakers...
YES...anyone knows that...
Old Sep 24, 2002 | 08:57 PM
MetaOrbit's Avatar
Got Projectors?
I had some Polk coax's in my old car. They sounded great - they sounded even better when they were amped. They only got removed to make room for my Memphis Components . Man I miss the front stage on that car...
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
