2000-2001 replacement grills?
Old Oct 12, 2002 | 09:05 PM
big h's Avatar
is it true? how is it so? i thought our grills were part of the bumper...needs to be cutout.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1867044841
Old Oct 12, 2002 | 09:20 PM
krazyd's Avatar
Is that just the grille molding without the actual grille inside? I'm confused as to what is being auctioned off there. Our grilles can only be removed if the entire front bumper is taken off, or if it's cut-out. I don't understand how this "replacement" would be installed. I wouldn't bid on it.
Old Oct 12, 2002 | 09:23 PM
BigDogJonx's Avatar
That is just the grill trim ring. It has like 8 screws. I actually hooked up grille up to that and cut the excess Street Scenes grille to get it to fit.
Dixit
big h's Avatar
exactly, i just emailed the seller to see what he says...
Old Oct 12, 2002 | 09:28 PM
big h's Avatar
heya bigdog!
my trim kit and the centerstack (the thing that holds the nissan emblem) are one...molded together . I wonder how you can hook that up to the bumper if you cut out the factory one...
Old Oct 12, 2002 | 09:39 PM
BigDogJonx's Avatar
Originally posted by big h
heya bigdog!
BigH you sure yours are one piece? The only ones that are one piece are the 2k2s but they have a totally different size opening, it is larger in the height.
Unless the Canadian maxes are like that, but I doubt that highly. The trim ring is held by those 8 screws, what you are supposed to do is cut AROUND those screw holes/mounts. If you cut them off, obviously aint nothing going to hold it up no more.
Dixit
Old Oct 13, 2002 | 03:26 AM
big h's Avatar
Dixit
I'm soooo confused...I'll check in the morning. I thought 2k and 2k1's need to be cut out, and the 2k2's were removable and required no cutting...
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
The Frye
Feb 3, 2019 08:34 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
