memory seat problems
Old Oct 24, 2002 | 10:40 AM
carguyrob's Avatar
Has anyone else had problems with their memory seats? I know that with the 6-speed, the emergency brake needs to be up in order to use them...but now they don't seem to work at all. They did work OK for the first month or so. The buttons will allow me to set the seat position in a memory position, but then it will never return the seat back to that position after moving it.
Any thoughts?
Old Oct 24, 2002 | 10:52 AM
ssp34's Avatar
Re: memory seat problems
Any thoughts?
Well, you'll have to press the button for the saved position you want to get back to while the car is in park (and in your case, probably with the hand brake engaged. I have an auto and I have to be in park before I can get the memory seat to move back to a saved position. Hope that helps.
Old Oct 24, 2002 | 10:54 AM
SHPatel's Avatar
I had this same problem...just take it to the dealer..it's common to alot of cars.
Old Oct 24, 2002 | 10:55 AM
2k2kev's Avatar
It's chrome alright...
Re: Re: memory seat problems
and make sure the switch on the dash is in the correct place. Someone might have accidently moved it to "off."
Old Oct 24, 2002 | 12:48 PM
carguyrob's Avatar
Re: Re: Re: memory seat problems
I didn't know that switch on the dash for backing the seat up when exiting did anything on the 6-speed. I will have to see if anyone moved it.
As for knowing that I have to actually save the seat position in memory...that seems pretty obvious. Besides, everything worked fine for the first month or so...
I will check out that switch on the dash.
Thank you.
Mar 12, 2020 12:06 AM
GregL65
Jan 17, 2020 08:01 PM
fakiesi
Sep 19, 2015 12:37 AM
slowlifer
Sep 8, 2015 05:53 AM
GregL65
Sep 5, 2015 09:37 PM
