Just had UDP installed!
The directions say that it will take 5-7 days for the ECU to adjust to the lighter pulley. 1st impressions are both good and bad. First off, the car fly's through the rpm's much faster, thus giving a feeling of faster acceleration. Second and the bad, you couldn't tell my 2k2 Auto was running while stationary and after the UDP was installed there is a slight jiggle when stationary. Doesn't matter if it's in drive, park or neutral. It's a tad more jiggly when the heater and A/C are on. Is this normal? Will the ECU correct this? What could be the problem?
Re: Just had UDP installed!
I gave the shop the directions and told them to follow them explicitely. I don't believe the directions said anything about the harmonic balancer on a 2k2. Just said to make absolutely sure to put anti-seize compound and make sure the sleeve is reinstalled. I've never noticed the jiggle before, but I am quite **** and notice everything if I don't do it myself.
Life sucks when you're like that! I suffer from the same "No one can do it right" syndrome!
Re: Re: Just had UDP installed!
Originally posted by DrVolkl
Are you sure the jiggle wasn't there before?? better make sure your harmonic balancer is installed on the pulley.
Its proabaly due to a lower idle.
MaxLife17
Jun 27, 2019 01:37 PM
