Friggin car STILL stalling...
Okay...I have now cleaned the intake of all oil, cleaned the MAF, cleaned the intake tubing, cleaned the accordian thingy AND thoroughly cleaned the valve body inside out too!!! Then, reset the ECU...
My friggin car is still stalling when I leave it idling in park or sit too long a stop light. I'm guessing I need to replace the MAF at this point. Any other suggestions???
Also, if anyone happens to know: Is the 01-03 MAF and tube the same as the 2K one? I'm thinking about renting a car soon...
ADMAN
ADMAN
TimW: Russ was the one that said he “successfully” cleaned his MAF. So, I think I will pull it off again tonight and see if there is still anything caked on the sensor. It was getting pretty late and rather dark out last night. I could have missed something.
Victor: I already checked with DaveB. But, I didn’t ask him to compare number. I was hoping to fix the problem first. I guess I may not have a choice since the MAF for m car is on serious backorder. Guess I’ll either have to live with it or just have Enterprise pick me up...
Max_Gator: I’ve already had the dealersh!t upgrade my code for the Cold Start problem. But, I may have the flash it again. I just hate arguing with them about mods. I might take it to another shop instead. I am having the same problem with staling after acceleration as well. So, it could be the idle setting or the MAF. I don’t know...
ADMAN
ADMAN
Re: Friggin car STILL stalling...
ADMAN
ADMAN
ADMAN
ADMAN
But it sounds to me like it is the ECU. I believe they also changed my idle setting.
By the way, I had the idle fixed about 1 year before the MAF had to be replaced. They had nothing to do with one another.
As you can see, DaveB has a MAF in stock now. So, I may have to get it anyway. He said it was about $100.00 as well.
I also had my idle fixed about a year ago. The car has been fine since. Now it is stalling. That is the only reason I don't think it is the ECU. It will idle fine until it starts to get hot. It will also sit and idle fine for a while. Then, all of the sudden, it drops to the 200-100 RPM range and dies.
I know there is a small vacuum control valve as well. But, I don't know how to test it accurately. The hose is connected and I can't find any vacuum leaks either.
Sucks to be me...
Sucks to be me...
Okay, I have now trackd the problem down to 20 second intervals...
Meaning, the car will try to stall every 20 seconds if left idling.
WHAT DOES IT MEAN???
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
altome15
08-10-2015 07:05 PM
