Could somebody have tried prying my HID's off?
Old Nov 12, 2002 | 09:31 AM
soundmike's Avatar
Very sound, Mike
I was replacing the bulbs on my 2k2 the other day and noticed that one of the the plastic tabs holding the headlight's in place was cracked right where the bolts go in.
Could this have been a sign that someone tried to tamper with the lights or could it have been over torqued from the factory. Will this cause any problems in the near future?
Thanks.
Old Nov 12, 2002 | 10:21 AM
emax02's Avatar
Re: Could somebody have tried prying my HID's off?
Thanks.
The little crack in those pieces are very commen.
Old Nov 12, 2002 | 10:22 AM
jjs's Avatar
jjs
Thanks.
Notice any NY/NJ plates in the area recently?
j/k
If it was from 'other than accidental reasons'...that SUX!
Is there any noticeable vibration due to a not fully secure bracket? I would think that might be your only problem.
Old Nov 12, 2002 | 10:25 AM
soundmike's Avatar
Very sound, Mike
Well i haven't noticed any unusual vibration, in fact - for the life of me - i couldn't even pull the headlight's out to install the bulbs. I ended up just doing it the hard way.
If it's a common crack i guess i can live with it.
Old Nov 12, 2002 | 10:57 AM
Step2kMax's Avatar
Thanks.
Well, when i installed may AE housing, i cracked one of my tabs by, yes over torque'n the bolt.
didn't completely split, but about a third the way. i might try and cement rubber glue it together or just leave it alone cause it hasn't gotten bigger.
Old Nov 12, 2002 | 11:11 AM
Padsy's Avatar
Boost.....
Re: Re: Could somebody have tried prying my HID's off?
Did you finish the 4th grade???
COMMON
Old Nov 12, 2002 | 12:16 PM
2K2SE's Avatar
Re: Re: Re: Could somebody have tried prying my HID's off?
COMMON
Technically it would be "is common" or "crackS...are common." I don't really care if emax finished 4th grade or not because he has the guts to try anything and as a result has the fastest NA 2K2 around.
All in fun.
Old Nov 12, 2002 | 12:52 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Vibrations will cause those pieces to have small cracks.
Old Nov 12, 2002 | 01:48 PM
Tanman's Avatar
Whew, you had me worried Soundmike, I thought the epidemic had reached our city! I was about to run out to the parking garage to check on mine when I read your thread title. Luckily in your case it was nothing to be concerned with.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
