Sqeaky belts?
Old Dec 6, 2002 | 12:06 AM
jykishan's Avatar
Sqeaky belts?
At first whenever i would start my car , and if the engine was cold i would hear a sqeaking noise comin from the engine, i opened the hood and could tell right away it was coming from the belts. But now it doesnt matter if the engine is warmed up or not, it always is speaking and it is really loud and embarrasing comin from this car. Anyone know what is possibly the problem??
Old Dec 6, 2002 | 05:02 AM
Larry's Avatar
Your belts are too loose. I wrote an instruction for installing an underdrive pulley in the "Installation Instructions/How to's" post that includes belt adjustment.
Old Dec 6, 2002 | 05:08 AM
PCGuRu2K's Avatar
Back when I had the UDP I got the squeek's too.. Just tighten them up a lil bit and you be good to go..
Old Dec 6, 2002 | 08:41 PM
jykishan's Avatar
i dont have UDP , but i'll check it out, thanx guys.
Old Dec 7, 2002 | 07:20 AM
oldmanmax's Avatar
belt dressing
a $1.99 belt dressing can from Autozone also help. You can spray the dressing to the part of the belt that you can see when you open up the enginee compartment. It is on your left as you are looking at the enginee.
Just don't go too long before tighten the drive belt.
Old Apr 8, 2003 | 10:55 AM
TRuFLiPpeR's Avatar
yeah, i donated....so?!?
here's another possibility...
when was the last time the belts were replaced? since you stated you don't have an underdrive pulley, they probably weren't touched since you purchased the car. if that's so, you could inspect for cracking or any other signs of obvious wear. if it needs to be replaced, just replace it and do it quickly. there's nothing more inconvenient than having your belts snap while you're driving. believe me, i know. hope that helped!
n1cK!
Old Apr 8, 2003 | 03:24 PM
jykishan's Avatar
I got this problem fixed a while ago, I had a warped powersteering pulley , you could see the pulley was completely ****eyed and wobbling as it was turning causing the belts to rub on the side of pulley. Fixed under my extended warranty
Old Apr 8, 2003 | 05:45 PM
TRuFLiPpeR's Avatar
that's good news
well, it's good that the problem was fixed, especially under extended warranty!
n1cK!
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
