HELP!!! Engine died tonite!
Old Dec 15, 2002 | 06:46 PM
KP ROX's Avatar
HELP!!! Engine died tonite! .. **Update**
Was entering highway and punched the gas to the floor, the car started to muster the power, in its autotragic way, and then died. Service engine light immediately went on and I couldn't get out of second gear. Pulled over, turned the engine off for about half hour. Tried to start, it would start, but then immediately died.
Can someone please tell me what the problem is. And most importantly if the solution is eligible for warranty (3yr/36K mile) Thanks.
Old Dec 15, 2002 | 06:53 PM
sascuderi's Avatar
Sounds like another 2000 MAF bites the dust. I notice you have a K&N filter, did you oil it recently?
Old Dec 15, 2002 | 06:58 PM
KP ROX's Avatar
No I haven't since I bought it, about 13k miles ago. Is the MAF same as O2 sensor?
Old Dec 15, 2002 | 07:11 PM
sascuderi's Avatar
No, MAF and o2 sensor are different. When the 02 goes, most people get a check engine light but the car will seem fine. The 02 sensors measure exhaust.
The MAF measures airflow in the intake after the filter. There is a problem with the MAFs in the 2000 Max and there is a TSB about it.
When the MAF goes the car will suddenly stall and then when you restart it will not go above ~2,500 RPMs
It is covered by the warrentee but make sure you take the K&N filter out when you bring it in or the dealer may give you a hard time. There have been suggestions on the forum that the oil in the K&N may in some way damage the MAF, especially if the person re-oils the filter and uses too much. So take the K&N out before going to the dealer!
STEVE
Old Dec 15, 2002 | 07:24 PM
KP ROX's Avatar
STEVE [/B][/QUOTE]
Thanks for the info Steve. I'm wondering though since the K&N has been in my car for 13K miles, and I've never re-oiled it, shouldn't I be in the clear.
Old Dec 15, 2002 | 07:29 PM
Jaws's Avatar
STEVE
Thanks for the info Steve. I'm wondering though since the K&N has been in my car for 13K miles, and I've never re-oiled it, shouldn't I be in the clear. [/B][/QUOTE]
Take the path of least possible resistance and put back in the stock filter. You don't want to give the dealer any ammo to deny your warranty claim. Remember we are talking about Nissan service
Old Dec 15, 2002 | 07:35 PM
chinaonnitrous1's Avatar
For some reason my 2k2 maf..with a dry apexi filter..it went boom too.
For some reason my 2k2 maf..with a dry apexi filter..it went boom too. .....mafs suck...nissan ones at that
Old Dec 15, 2002 | 07:46 PM
sascuderi's Avatar
Yes, you are in the clear in that it is very unlikely that the K&N caused the MAF to go. Since there is a TSB about the MAF that only proves they are defective. However, some dealers for some reason like to find a reason to blame the owner of the car for the problem so just replace your K&N before you go in for service.
Please let us know if it does turn out to be the MAF, Thanks!
Old Dec 15, 2002 | 08:16 PM
y2kse's Avatar
and rotors
and ignition coils
and O2 sensors
and . . .
Old Dec 15, 2002 | 08:46 PM
KP ROX's Avatar
I threw out my stock filter last year, just bought a new stock filter tonite and will use to replace k&n temporarily.. I wonder if they'll question how there is a brand new filter with zero dirt on it. hmmm..
Old Dec 15, 2002 | 08:56 PM
Wasim521's Avatar
Hehe, that's why I keep a slightly used Nissan paper air filter in my trunk, just in case...good luck with Nissan.
Old Dec 16, 2002 | 08:59 AM
KP ROX's Avatar
Re: HELP!!! Engine died tonite!
Just an update... Dealership looked at the car this morning. I bought a stock filter to replace the K&N temporarily, however, I remembered that the dealership (Courtesy) sells K&N filters. So just left the K&N filter in there (thinking they can't blame the K&N if they sell it)
Turns out it was the MAF sensor, and they replaced it under warranty, without a peep. Dang I'm having a good day.
Old Dec 16, 2002 | 09:00 AM
Stikya's Avatar
Check to make sure the air intake is still attached securely in all connections between the MAF and throttle body. Mine feel off about 1 month ago, and I had the same symptoms.
Old Dec 17, 2002 | 05:44 PM
sascuderi's Avatar
Glad to hear they fixed it without a problem.
How many miles did you have on the car?? (I wonder if all the MAFs tend to go at the same milage)
Old Dec 17, 2002 | 07:54 PM
KP ROX's Avatar
I have 32k on it right now, hopefully it'll last at least another 32K more. Heard it is horribly expensive to replace outside of the warranty.
Old Dec 18, 2002 | 04:11 PM
sascuderi's Avatar
It is, but some time back someone posted that you can get just the sensor and not the tube and sensor (which the dealer tends to replace in this situation) for a lot less money. Does anyone know if that is still the case?
shilov
Feb 19, 2024 09:40 PM
sctludwig
Sep 1, 2022 01:32 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
viperboy
Sep 27, 2015 07:05 PM
Socalstillen
Sep 20, 2015 11:46 PM
