is my synchro going bad??
Old Dec 25, 2002 | 10:59 AM
mjg's Avatar
mjg
hey
I'm new to stick shifts, my first car that has had one, so i wanted to ask you guys how you felt:
Every now and then when i go to throw my car in third, it feels as it wont go in, only at certain rpms i think... i haven't noticed consitancy yet but, if i pushed hard enuf, it would go into first instead of third.
I had dropped into first a few times, and i'm real glad i wasn't stressing the car, so i don't think i damaged it doing that...
I'm just throwing the stick straight up from neutral to third and it just doesn't slip in... Could this be a damaged synchro? If so, why doesn't it happen all the time?
Who has had this happen?
Old Dec 25, 2002 | 12:31 PM
max2001se's Avatar
Re: is my synchro going bad??
Originally posted by mjg
hey
If you have a 02 six-speed then you probably have the same problem many people have had on their 02's. Do search and you'll find numerous threads on third gear issues with the six-speed.
Old Dec 25, 2002 | 12:43 PM
mjg's Avatar
mjg
k thanks... i would hav enever thought that this would be a common issue.
Old Dec 25, 2002 | 02:25 PM
Triple8Sol's Avatar
I miss the .org!
When I shift fast into 3rd on my 2K2 6speed, sometimes I get the grinding noise, as if I didn't have the clutch fully pushed in. Is that synchros too?
Old Dec 25, 2002 | 02:52 PM
mjg's Avatar
mjg
from what my buddy was saying, if the transmission is spinning too fast and the clutch isn't push quick enuf or fully engaged that happens. He said if the car is put into gear normally and perfectly and still grinds, that might be a synchro. I hope that helps.
Old Dec 25, 2002 | 04:24 PM
emax02's Avatar
hey
Just sounds like you have a notchy 3rd gear, it's a ery oomen problem. It seems that 2002's suffer form this a bit more then 2003's..
The grinding noise is comming from the syncro, saying it's a problem or not really depends. A good tranny should never have a grinding gear. An occasional gear grind on a 2002 is normal though.. Once it starts happening all the time you have a real problem(like me).
Old Dec 25, 2002 | 06:33 PM
mjg's Avatar
mjg
Re: Re: is my synchro going bad??
hey man i really hope so... thank you for the advice. hey speaking of which, what kind of y pipe do you have on your 02 max? I was under the impression we couldn't get these yet.
Old Dec 25, 2002 | 08:25 PM
emax02's Avatar
Re: Re: Re: is my synchro going bad??
I have had a stillen y-pipe on since about last May.
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
