Home Depot Gutter Guard Grill Question...
Old Jan 18, 2003 | 03:33 PM
spta97's Avatar
..where would I get a U-gasket or something similar for covering the sharp edges when making my own Home Depot Gutter Guard Grill? I think that grill-tech uses a U-gasket (basically a rubber "track" that the metal grill goes in so it doesn't scratch the paint).
Old Jan 18, 2003 | 03:51 PM
vqman
Re: Home Depot Gutter Guard Grill Question...
I have no idea, but I wanna see pics when you're done...
Gutter Guard?
Can this be done with a professional look?
I have no idea....really, ask anyone, i'm clueless...
-vq
Old Jan 18, 2003 | 04:40 PM
MadMax1996's Avatar
What about the automotive trim that people use on the edges of their doors? I've seen it in black & clear.
Old Jan 18, 2003 | 08:34 PM
00MaxSE's Avatar
Pointy Elbows
When I installed mine, I stuck in up into the splash gaurd under the car and zip-tied it to the vertical plastic pieces. It fit perfectly and didn't have to worry about scratching the paint.
Old Jan 18, 2003 | 10:27 PM
LatinMax's Avatar
I marine text all of mine on my car, primered it and painted it. Check out my site and see it looks pretty good.
Old Jan 18, 2003 | 11:04 PM
MaxDoogie's Avatar
When I did it, I just did it behind the valence...But after going to home depot to get some weatherstripping to fix the rattle in the rear deck of my girlfriends car, I think you could use some of the heavy duty rubber weather stripping...You could easily mold it around the mesh and it comes in clear too...so it would hardly be visible
Old Jan 18, 2003 | 11:49 PM
2M0A0X2's Avatar
huh! what did you do!?
Old Jan 19, 2003 | 07:25 AM
doublea's Avatar
Hey spta97, I found some door edge molding, it's call TrimBrite made by Spartan Plastics Canada ltd, I bought this at Canadian Tire for 10$ the good thing about these door edge is they have some glue in it and there available in black - chrome - gold and many other colors. I made my grill almost 1 year ago and it is in perfect condition, the only thing is I was unable to find a lenght over 27".
Good luck.
AA
Old Jan 19, 2003 | 01:35 PM
2M0A0X2's Avatar
Re: Re: Home Depot Gutter Guard Grill Question...
Good luck.
AA
lol, lucky us canadians, we have canadian tire...i don't think spta lives in canada tho
Old Jan 19, 2003 | 08:11 PM
Andrew's Avatar
would the zip ties start to wear on the vertical plastic pieces? The pieces are painted...no?
A-
Old Jan 20, 2003 | 06:35 AM
Hotnicks's Avatar
That's a pretty good idea. I should have thought of that before putting the gutter guard on my grill. Unfortunately, I was so exited about seeing how it was going to look, that I just placed it in between the horizontal bars of the grill without thinking about the possibility of scratches. So needless to say, I have a few scratches on my main grill. It really isn't necessary on the valance. I cut the valence just a bit small so that wouldn't happen.
Here's a pic of my grill and valence.
Check out more pics on my home page.
Old Jan 20, 2003 | 07:16 AM
spta97's Avatar
Gutter Guard?
-vq
This is using a gutter mesh screen (kinda diamond pattern) in the grill (lower in my case) to save a couple bucks!
Excellent Idea…gonna check this out today.
The 2k3 grill doesn’t work by putting the mesh screen behind it…it really has to be put in front.
Good luck.
AA
Good find! They are supposed to sell it in the US (where I am) so I’ll look for this today as well! Thanks.
A-
I didn’t think about this…however this is how even the after market ones are done (for the most part according to Grill-Tech.
The 2k3 grill is different. I’m only trying to do the lower valance, but it really needs to be put in front.
Here is a pic of what the aftermarket one by Grill-Tech looks like:
It might be worth it to spend the $60!
Old Jan 20, 2003 | 10:53 PM
2M0A0X2's Avatar
how u do that?
Old Feb 13, 2003 | 11:12 AM
2M0A0X2's Avatar
Originally posted by 2M0A0X2
how u do that?
hello?
Old Feb 13, 2003 | 11:24 AM
Hotnicks's Avatar
hello?
Sorry, must have missed your post! Wasn't trying to ignore you.
I basically took the home depot gutter guard mesh and cut it into the small sections you see in the pic. The best way is to use cardboard to make templates of each section and then cut the mesh from that. I cut the mesh about .5 to 1 inch larger than the template, and bent the excess mesh.I tried to bend all the angles so that the bent sections went into the grill. This way it has a bit of a 3D look when looking at it from the sides. Then just paint it whatever color you want, and voila! Using small zipties will hold it in place.
Old Feb 13, 2003 | 11:33 AM
2M0A0X2's Avatar
whoa, thanks a lot man, i gotta try it on a 2k2 now...maybe today or tommorow...5 day holiday for me!
Old Feb 13, 2003 | 11:50 AM
Hotnicks's Avatar
Good luck
Some suggestions...
Try and find some type of "rubber" track that spta97 started the thread about. It would prevent your grill from getting scratched up.
Also, get some kind of heavy duty wire cutters, otherwise, your hands will hurt from all the cutting
Old Feb 14, 2003 | 12:23 PM
Neal728's Avatar
On a 2K2, is there any way to do this valance idea with the gutter mesh, or do I have to figure out a way to put it in front?
Old Feb 14, 2003 | 12:26 PM
Neal728's Avatar
One more thing, is it possible to remove the ooglie plastic trim inside each hole on a 2K2 valence? I'd rather just remove that and then figure out a way to install the mesh....
Old Feb 14, 2003 | 01:34 PM
xfirepwr1's Avatar
[QUOTE]Originally posted by Hotnicks
I like that idea as soon as it gets wormer here in Chicago I will try it and if it doesnt work on my 2k2 Ill just try and put it over the stock grille. It beats paying $200 for the lower vellence and grille
Old Feb 17, 2003 | 07:37 AM
Hotnicks's Avatar
Neal728: Look at the pic posted on the first page of this thread (Kloogy's car I believe). You can do something similar with the gutter guard.
2M0A0X2: Have you tried this, how did it turn out? I'm curious to see how it came out for you...
Old Feb 17, 2003 | 09:30 AM
2M0A0X2's Avatar
no, i haven't tried it yet because this weekend, it was cold up here in the north, home depots here don't have gutter guards....lmao, u wanna send me some?? haha, yeah, so i gotta look around at other hardware stores for it.
Old Feb 18, 2003 | 02:16 PM
2M0A0X2's Avatar
alright, i tried it with a little chicken wire (wasn't gonna leave it on), just to try, and i found it really hard to bend it and make it look as good as yours....how did you bend yours to make it look 3d like that?
REDinLV
Aug 15, 2024 12:30 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
