JIC Ride Problems......please help
Old Jan 28, 2003 | 09:21 PM
Bulldawg's Avatar
I just installed these on my 2k2. I have the dampening set to zero. Also I have loud clunking noises coming from the rear when I hit a substaintial bump(like a pothole, or a raised walkway). kinda like a "hollow" thud. Does anybody have any sugg. I will be taking the wheels off tomorrow to adjust the height, and while I am there I will check to see if everything is in place. Any help????
Old Jan 28, 2003 | 09:59 PM
SVTTODAMAX's Avatar
Check your tire look for rub marks or cuts im not having any problems what so ever. I will help you with any questions you have. What kind of tool did you use to measure the height and preload of each coilover? It's hard for me to determine what could be the problem just by the little info you gave me. If I had to make a assumption it is either the spring has play in it, or the upper bolts aren't tight,or the car is sitting to low. If the spring isn't set correctly it will cause the strut to fully extend and make a thud sound especially if you have it set to zero dampening. When you check the spring preload make it have zero play and add a 1/4" to it then measure it and make sure the other side is exactly the same use calipers or some type of measure device and try to be within +/-1/8".
Old Jan 29, 2003 | 03:08 AM
Y2K2Driver's Avatar
Could it be the RSB hitting? I know that is something that I'm going to be adjusting during coilover install to make sure I don't have any problems with it.
Old Jan 29, 2003 | 08:24 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
That is EXACTLY what it sounds like.
Which one do you have?
Old Jan 29, 2003 | 09:30 AM
Bulldawg's Avatar
the ADDCO RSB but what exactly is it hitting
Old Jan 29, 2003 | 09:36 AM
Y2K2Driver's Avatar
The Addco's brackets that attach to the beam stick out a little bit where the bolts go through and it is possible for them to hit, on the passenger side, the mechanism that allows for vertical movement in the beam. Move them towards the center a bit and/or grind the bracket down a bit.
http://mywebpages.comcast.net/mpillm...spension_1.pdf
I believe its part#13 in the diagram of the rear suspension that it is hitting.
Do you how easy it is to manipulate the beam and determine whether or not its going to hit with the rear struts out? I'm hoping I will be able to get underneath and jack it up and see directly whether my current settings will cause a problem with the car lowered.
Old Jan 29, 2003 | 10:37 AM
IceY2K1's Avatar
I don't have that bar, so I couldn't tell you. However, there are plenty of threads on that bar around, so use the search.
BTW, you should see the marks if it is hitting.
Old Feb 6, 2003 | 01:09 AM
JIC A33's Avatar
Did a JIC dealer install them??? These should not be installed by someone who doesn't know how to tune or install twin perch coilover systems. It's not hard. Just need to know what's up. Cause you could damage it. That's a lot of money to waste. you should contact your dealer. That's their job and shows for customer service.
A couple of brief pointers.
You just barely want preload on the springs.
Tighten the pillowball nut all the way. and I guess look into that RSB problem.
Old Feb 6, 2003 | 04:19 AM
Y2K2Driver's Avatar
What areas could be damaged?
Old Feb 6, 2003 | 05:46 AM
Blackgums100's Avatar
Which dealer?
Are you talking about the Nissan dealership? laugh, you would be truly lucky to find a dealer willing to install them. Or are you talking about who he purchased them from? Either way you seem to be a JIC guy, welcome to the org.
Old Feb 6, 2003 | 08:36 AM
lcf's Avatar
lcf
Could you name me a couple JIC dealers in Chicago who would be able to install these on my 5th gen?
Old Feb 7, 2003 | 11:53 PM
JIC A33's Avatar
Please contact these guys:
http://www.a-spectuning.com/
They are good friends. Talk to Sean. Have him call me when you go in. He's in Addison. Take the time to see them. They work on my favorite cars, RX7's. What I'm a proud owner of several. lol.
Peace.
Old Feb 8, 2003 | 10:30 AM
K Pazzo 6's Avatar
Peace.
cool i live close to addison.....what does sean know you by?(JIC A33???)
Old Feb 8, 2003 | 04:43 PM
JIC A33's Avatar
Tell him Mr. FC3S from San Jose sent ya. hehe. I'd prefer not to post my name, but let him know I'm the Kinesis guy. lol. Have him call us as well so I can make sure he's got all the info needed for this. They are dope and do very high end **** to RX7s.
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
