Finally fixed rear deck rattle
Old Feb 28, 2003 | 06:52 AM
GaMax97GLE's Avatar
After putting back my 3 12" and Xtant 1001d, the rear deck rattled BAD. The only way to not hear the rattle was to max out the volume. Last night I decided that I couldn't take it any longer. I removed the rear seat bottom, sides, and plastic pieces to get at the rear deck. I seperated the rear deck lid from the metal but didn't take it out of the car since the seat belts still went through the deck lid. While I had the lid off I removed the stock Bose sub to use that hole as a port, not sure how effective it will be but it couldn't hurt. I also removed the middle seat belt and the anchor points for a child seat. I then used fake Dynamat (the roofing "Peel & Seal") and covered most of the metal deck, using the butt of an exacto knife to get in the corners and to matt it down real well. I flipped the deck lid over and layed .25" carpet pad on it and cut out a rough shape. Then cut holes for the attaching points, remaining seat belts, 3rd brake light, Bose sub hole, and the blue foam supports. I then hot glued the pad to underside of the lid and re-installed it. I put everything back together and remounted all the plastic piece on the lid so it looks like it was never touched. I tested it out this morning on the way to work and there is not one rattle! It actually sounds better, a lot more solid. This weekend I'm going to line the inside of the trunk and the license plate to fix the exterior rattles. A good cheap night of fun.
Old Feb 28, 2003 | 08:05 AM
HondaKilLR's Avatar
About the bose sub. I was thinking, could it be BETTER to leave it in place unpowered and use it as a baffle/resonator to the real subs? PLus I feel it would benefit as added weight to the rear deck to hold that sucka down. Or is the port the way to go? Just a thought....
Old Feb 28, 2003 | 08:20 AM
HondaKilLR's Avatar
Just noticed my sig!!!! Woo Woo!!!
I need to post more! I'm on here like everday....
Old Feb 28, 2003 | 08:36 AM
PoweredbyNissan
Do you have an aftermarket headunit in there too?
If so, what did u do with ur factory bose speakers and amp?
Old Feb 28, 2003 | 08:40 AM
GaMax97GLE's Avatar
I think I like it ported like that. With the carpet pad and Dynamat under the lid, that's enough to keep all the rattles away/ Plus, the weight of the sub won't matter because it bolts to the metal deck and not the hardboard lid.
Old Feb 28, 2003 | 08:44 AM
GaMax97GLE's Avatar
No, I kept everything inside stock. I ordered this: http://www.go2pac.com/oem1kits/aoemr...or+AOEM-1+kits so I can use RCAs, but it hasn't arrived yet so I had to tap into the Bose speaker to get the signal. I am going to upgrade the tweeters in the A-pillars though. I do have the Bose sub in the basement now, but I think I will keep it in case I ever sell the car.
spta97's Avatar
I hade mine on there for a day after my sub install and all I heard was distortion. Removing it was the best thing I ever did. The port is a nice way for the bass to get into the cabin and as far as the weight holding the deck down it only weighs 2 lbs. at best. My advice, get rid of the whole system...I did and mine sounds awesome!
Old Feb 28, 2003 | 09:00 AM
PoweredbyNissan
Doesn't that gives u a rather not strong of a signal as if you had a RCA out from the back of an aftermarket HD? How do u live with that?
btw, what gauge wires are u using for the wire that goes from the factory sub to ur amp?
HondaKilLR's Avatar
S
Old Feb 28, 2003 | 09:11 AM
GaMax97GLE's Avatar
The signal is fine. I think it could be better (cleaner) if I ever get the harness.
Regular (but thick) speaker wire that merges into RCAs. All that will be scrapped when the harness arrives.
Matt93SE
May 24, 2019 02:58 PM
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
maxinout93
Aug 16, 2015 07:25 PM
Mcnabb34
Aug 11, 2015 08:45 PM
