HID in a 01?
Old Mar 16, 2003 | 06:31 AM
mxmerc's Avatar
HID in a 01?
I was wondering if anyone knows if the HID lights out of an '02 or '03 would fit in a 2001 maxima. And if so what must come with the light, burner, casing, etc?
Old Mar 16, 2003 | 06:51 AM
KennyLau's Avatar
Re: HID in a 01?
The HIDs for the '02 and '03 Maxima will fit into the '00 and '01. However, rewiring needs to be done.
You can request a write-up from BigDogJonx. His webpage is at:
http://mywebpages.comcast.net/dsuthar/howto.html
Or you can request a write-up from IceY2K1. His webpage is at:
http://maxima.cardomain.com/member_p...=143972&page=6
Due to the HID theft problem with the Maxima, write-ups tend to be given out on a prove-you-purchased-the-HIDs-legitimately basis, so check with the people who did the write-ups for more info.
If that's too much trouble, have you thought of just replacing your existing headlight bulbs with Sylvania Silverstars? $50.00 or less for a pair to give a HID-like brightness. Just a thought.
Good luck. Peace.
Old Mar 16, 2003 | 08:15 AM
skandalouz's Avatar
Re: Re: HID in a 01?
Good luck. Peace.
i think the newer headlights themselves look better than the old ones. not just the fact that their brighter.
Old Mar 16, 2003 | 08:29 AM
92 SE-R 02 SE
Re: Re: Re: HID in a 01?
New lights are A LOT more aggressive lookin
Old Mar 16, 2003 | 10:05 AM
max...to the ma's Avatar
amen to that
Old Mar 17, 2003 | 12:41 AM
E-Man01's Avatar
Re: HID in a 01?
Not only will it cost an arm and a leg to get, you have to worry about getting them ripped off from low-life losers. Consider getting a Catz-HID kit or some equivalent (with a dual beam), which will cost around 500-600 dollars. Then you will have true HID's and I am sick of changing burned out bulbs all the time. I have to admit though that the 2002 headlamps look sweet and they are a perfect fit.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
