Should i remove the stock air scoop or leave it alone?
Old Mar 18, 2003 | 06:55 PM
LouE37's Avatar
I've had my Stillen intake for about 6 months with no problems at all. I have left the stock air scoop and sensors right where they are but I was wondering if there is a better way to deal with this. I know people have removed them but i wasnt sure what the best thing to do would be. I guess if its not broke dont fix it but if that was the case then why do we mod our cars right.
Old Mar 18, 2003 | 07:28 PM
y2kse's Avatar
Re: Should i remove the stock air scoop or leave it alone?
Right!
Old Mar 18, 2003 | 09:02 PM
E55AMG2's Avatar
Wat
Re: Re: Should i remove the stock air scoop or leave it alone?
Originally posted by y2kse
Right!
true.
Old Mar 19, 2003 | 02:09 AM
Max_Vader_2K's Avatar
Re: Re: Re: Should i remove the stock air scoop or leave it alone?
Originally posted by E55AMG2
true.
DITO!
Old Mar 19, 2003 | 04:02 AM
PCGuRu2K's Avatar
Well most ppl take it off.. Just make sure you zip tie that temp sensor somewhere that comes off. Other then that's it'll be ok
Old Mar 20, 2003 | 12:39 PM
Phoenix1911's Avatar
it dumps road moisture directly onto my pop charger making the whistling noise louder when driving in the rain, plus all the dirt and grime gets deposited onto the filter so I'm thinking about removing it.
There are two sensors, one conects to the +ve battery terminal, whats that do? The other is actually labeled "Boost Sensor" and disappears into the wiring harness! Where is a good place to stash these? Do they need airflow over them?
Old Mar 20, 2003 | 12:50 PM
kjpierce's Avatar
i left mine on.
by leaving it on , won't it bring fresh air into the engine bay?
if you take it off you will just be sucking hot engine air. right?
i am not sure ,that is how i see it. if i am wrong please tell me why
not looking to get flamed
just making an educated guess.
Old Mar 20, 2003 | 02:06 PM
y2kse's Avatar
The sensor mounted in the stock air scoop is the air intake temperature sensor. If you remove that sensor from the scoop and mount it inside the engine bay, you will remove it from a source of fresh air and expose it to heat soak from the engine.
I don't know about you, but that just never seemed like a very good idea to me.
Old Mar 20, 2003 | 02:18 PM
scmaxima2k's Avatar
yeah i left mine on figuring that it would funnel the air towards the filter so it wasnt suckin in hot air. So i dont see any reason to take it off.
-Steve
Old Mar 20, 2003 | 02:46 PM
HitManSE's Avatar
This was discussed my y2kse, myself and several others a few months back. If search was still around then u would have found it. But u want to keep the sensor in the path of fresh air because thats kinda the way the engine knows how dense the air charge is. (by the temp, thats y colder it is better=more dense=more power!)So w/o this reading the ecu doesnt know how much fuel to throw in to keep a good A/F ratio. Not really a huge diff, but it will throw an SES if not pluged in so dont remove it.
The Frye
Sep 2, 2021 11:03 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
crazyespn
Sep 3, 2015 01:30 PM
