Idling Question
Old Mar 25, 2003 | 10:49 AM
2kprlmax's Avatar
Idling Question
When you start your car and it is warmed up at what rpm are you Idling at? Mine is at 500rpms, is that normal, I've heard it should be like 700/800 rpm.
Old Mar 25, 2003 | 10:58 AM
y2kse's Avatar
Re: Idling Question
No. 500 rpm is too low. Go to your dealer and have them bring it up to spec.
Old Mar 25, 2003 | 10:59 AM
NT2SHBBY
Re: Re: Idling Question
why would low rpms be bad???
I was always taught to believe that you WANT low rpms, shows that the car is running smoothly.
Old Mar 25, 2003 | 11:01 AM
2kprlmax's Avatar
thats why i thought too, what are the pros and cons of high and low rpms
Old Mar 25, 2003 | 12:23 PM
Phoenix1911's Avatar
I think the specs are 650-750 for manual tranny, when engine is at normal operating temps, and autos I think were in the same ball park but i don't remember if it was 50 lower or higher??
500 is to low... Your timing will be off spec, and you are borderline luging the engine, bad for your rings... You may also find your engine studders when accelerating from a stop???
Old Mar 25, 2003 | 01:41 PM
y2kse's Avatar
The fact that your engine idle is out-of-spec may also be a symptom of a bigger problem. If it was my Maxima, I'd get it into the dealer right way.
Consider yourself warned.
Old Mar 25, 2003 | 01:52 PM
studman's Avatar
Per the ESM:
Once the engine is warmed up and the car is idling, the tach should read the following:
Manual Transmission - 625 RPM +/-50 RPM
Automatic Transmission - 675 RPM +/-50 RPM
If it's not, which your's isn't, get it to the dealer soon. It could be signs of a bigger problem.
Old Mar 25, 2003 | 02:07 PM
VMaximus02's Avatar
Originally posted by studman
Per the ESM:
I've posted a similiar thread before. Where were you?
http://forums.maxima.org/showthread....hreadid=198400
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
